Light Switch Question, Possibly A 3-way - Electrical - DIY Chatroom Home Improvement Forum
Old 03-17-2009, 03:52 PM   #1
Rewards Points: 101
Light switch question, possibly a 3-way
Trying to figure out how to make one of my lights into a 3 way.
Right now I have 2 lights in my kitchen controlled by 2 switches, but on the other wall there was a switch that wasnt hooked up to anything, and I am hoping I can make it a 3-way to control one of the lights in the kitchen/dining are.
Here is a picture of the switches that are working now, the one on the left controls dining, right kitchen. i am guessing that the kitchen/right side switch isnt set up for 3 way since it only has 2 wires, hence no traveler?
Here is the box where there was a switch but not hooked up to anything
And here is the ceiling box for the light
What do I need to hook up to make this a 3-way system or is that even possible?
mikereno1 is offline   Reply With Quote
Old 03-17-2009, 05:14 PM   #2
Remodeling Contractor
no clamps on these wires? no grounding screw? Who did this hack work? you need to get an electrician and determine how bad your house wiring is.
Old 03-17-2009, 05:46 PM   #3
Rewards Points: 1,418
You will need to string a 3 conductor cable between the switch locations in order to have a 3 way switch setup.
Now I don't know who makes one but there may be such a thing as a wireless three way switch kit that would let you use the existing switch location with just a 2 conductor cable. This is not what is known as a 3 way dimmer, that also needs 3 conductor cabling.
Old 03-17-2009, 05:53 PM   #4
In your case an electronic X10 switch can be programmed to work as a dimming three way from either location since the same power and neutral are available. The typical travelers in a 3 wire between switches are not needed for these switches. You can find them at www.smarthome.com
no power going to the light switch baseballfan Electrical 18 09-08-2008 06:35 PM
Problem changing light switch grgryl Electrical 14 08-10-2008 02:26 PM
GFCI light switch trips once per night ???? mw6263 Electrical 11 07-25-2008 12:05 PM
Connecting a Ceiling fan to a Light Switch AceAvenue Electrical 6 06-03-2008 04:06 PM
New light switch burns out dsbutler71 Electrical 12 09-05-2007 08:34 PM
