Light Switch Question - Electrical - DIY Chatroom Home Improvement Forum
Old 11-27-2012, 02:44 AM   #1
Rewards Points: 12
Light switch question
I dont know much about electrical but this might be an easy one for you guys.
Im trying to do this by memory so bare with me...
Lets imagine a hallway light that is connected to 2 switche. One at point A of the hallway and one at point B of the hallway.
When switch A is down and B is up the light is OFF and switch B wont function (wont turn light on/off)
When switch A is up and B is up the light is ON and either switch will turn the light off
But, When switch B is down and switch A is up the light is OFF and switch A wont function
Hopefully you can understand what im trying to say here.
This doesnt seem right to me. obviously the wiring for these 2 switches are connected to the same light.
Is a wrong switch installed or is this common?
Robert95z is offline   Reply With Quote
Old 11-27-2012, 05:34 AM   #2
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
It is not common.
To control the light from 2 locations you need 3 way switches that generally have 3 wires connect to the switch.(black,red&white.).
sublime2 is offline   Reply With Quote
Old 11-27-2012, 05:39 AM   #3
Rewards Points: 12
Do you think 3 ways can be added? I'm not sure what it looks like behind the switch
Old 11-27-2012, 06:45 AM   #4
Rewards Points: 1,296
Do the switches have "ON" and "OFF" on them or are they blank? Sounds like you have a 3-way setup that was wired wrong when someone changed switches
danpik is offline   Reply With Quote
Old 11-27-2012, 06:56 AM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Has it ever worked correctly? If was working and stopped working (and no one has changed anything), then 1 of the switches is bad.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 11-27-2012, 12:44 PM   #6
joed's Avatar
Rewards Points: 12,892
It sounds like you have single pole switches installed instead of three ways. You need three way switches to make this work. Turn off the power and pull the switches out but co not disconnect any wires. Tell us what you see or take some pictures and post them.
Old 11-27-2012, 12:46 PM   #7
Rewards Points: 2,516
There are plenty of 3-way switch articles and diagrams on this forum. Look at this post:
3-way switch
hammerlane is offline   Reply With Quote
Old 11-27-2012, 04:16 PM   #8
Rewards Points: 12
Looking at both the switches they look the same.. Top left has a red wire, bottom left is a bare copper wire, top right is a black wire and bottom right is a black wire.. I did not pull the switch out of the box, but heres some pics...
Any ideas?
Light switch question-photo-1.jpg   Light switch question-photo-2.jpg   Light switch question-photo-3.jpg   Light switch question-photo-4.jpg
Old 11-27-2012, 05:38 PM   #9
Oso954's Avatar
Rewards Points: 1,116
Those are cooper 3ways that look recently installed.
You seem to be avoiding the subject in spite of questions like "did they ever work"
We can't tell which black is which from your pics. You need to pull the switches out (leaving wires connected) and take the pics again so we can see the cables and wires in the box.
Oso954 is offline   Reply With Quote
Old 11-27-2012, 05:39 PM   #10
Licensed electrician
Rewards Points: 1,622
Is the black in the cable with the red on the brass or black screw? If it is on the black, move it to the brass. Restore power and test.
Old 11-27-2012, 05:47 PM   #11
Rewards Points: 12
This is a new construction home. It's been like this since day 1.
I'll take the switch out of the wall and take a picture of it. I'll have it up in a couple hours.
Old 11-27-2012, 06:37 PM   #12
You most likely have one of 4 situations for your 3-way switch/light configuration:
1. power into switch location----light----other switch location
2. power into switch location----other switch location----then light
3. power into light location-----traveler cable to switch----- traveler cable to other switch
4. a variation of #3 but here the traveler cables for the switches are run to/from the light location
Do not get to hung up on the color of the wire insulation in as much as the function of the wire. I do not show any ground wires just for ease of drawing.
Light switch question-111.jpg   Light switch question-222.jpg   Light switch question-33.jpg   Light switch question-444.jpg
Hot wires on both sides of switch RedRumLoki Electrical 4 11-20-2012 09:37 PM
Simple Question on Light Switch Series hagler Electrical 19 03-20-2012 07:46 AM
2 Wires in to light, 3 Wires out, no juice on the switch prytoo Electrical 4 11-28-2011 05:24 PM
Basic light wiring question speedster1 Electrical 3 11-29-2010 06:48 PM
A simple 2 light --1 switch question? redondo11@msn.com Electrical 7 11-05-2008 08:35 AM
