Light Switch Problem - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-16-2011, 02:42 PM   #16
Mad Scientist
I'm not entirely certain how you have this wired. Let me try to clarify:
You should have the constant hot connected with a wirenut to one of the two black wires in the first pipe, and also to a six-inch length of wire connected to one of the screws on the switch. The other black wire in the first pipe should be connected to the other screw on the switch.
I can't recommend using the push-in holes on the back of the switch. They make a very weak connection and have a habit of falling out or burning up, especially if there are outlets on this circuit that a vacuum or something might get plugged into.
McSteve is offline   Reply With Quote
Old 03-16-2011, 02:55 PM   #17
I understand, so to by pass putting the wire in the back of the switch which is very hard to do I will buy some extra wire to make the six inch one to attach to the hot wire and black wire and then to the switch. Is that correct? Thanks for all your time.
firefox93109 is offline   Reply With Quote
Tags
no electricity
Ceiling Fan and Light Switch Problem desiboy Electrical 3 03-03-2011 01:09 PM
Light Switch Problem duityourself Electrical 5 07-11-2010 08:42 PM
Light switch installation problems pc_clone Electrical 8 11-30-2009 10:25 PM
Weird Problem with new light.... MRTOWNDRO Electrical 8 12-21-2008 05:00 PM
double switch problem jim70 Electrical 5 05-02-2008 08:55 AM
