Light Switch/outlet Combo, Load Issue - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 04-30-2012, 08:25 PM   #31
Originally Posted by k_buz View Post
Plug these items into a separate lighting circuit. Into a living room outlet or a different bedroom outlet, not the kitchen counter top outlets, bathroom outlets, or dining room outlets.
Turn on all the lights in the house and see if this happens on other circuits as well.
The lights issue only happens when hair dryer plugged into newly installed outlet on the same circuit as lights. Plugging hair dryer into any outlet on another circuit does not causing lights problem. Also when hair dryer is plugged into the new outlet, no other lights on any other circuit in the house flickers or dims.
xiea is offline   Reply With Quote
Old 04-30-2012, 08:28 PM   #32
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Did you wrap the wired around the screw terminals? or backstab them?
Old 04-30-2012, 08:43 PM   #33
Wires are wrapped around the screw terminal and screwed down tight. The only wiring I did was to pigtail a wire out of the existing bunch of neutral wires.
Old 04-30-2012, 08:47 PM   #34
k_buz's Avatar
I would double and triple check the neutral splice and the hot splice (even though you didn't do anything to it).
After that, I don't know what else to tell you.
Old 04-30-2012, 08:51 PM   #35
I was afraid of that. I already checked the splice and don't know what else to do.
Old 04-30-2012, 08:59 PM   #36
I=E/R
a7ecorsair's Avatar
If you take this appliance, what ever it is, and plug it into another duplex receptacle somewhere in the house and plug a lamp into the other half of the receptacle, do you see the blinking?
a7ecorsair is offline   Reply With Quote
Old 05-02-2012, 02:13 PM   #37
There's no blinking.
Tags
load , switch plug combo , wiring
ceiling fan light issue after replacing electrical panel texan206 Electrical 3 04-21-2012 11:33 PM
Ceiling Fan And Light Combo alphyone Electrical 1 05-20-2011 03:34 PM
Whirlpool Microwave light issue mustangcobra44 Appliances 8 08-14-2008 03:52 PM
replacing vanity light...issue with outlet box? tarheelblue Electrical 5 01-28-2008 09:20 AM
Light fixture issue baustin Electrical 4 07-17-2007 04:01 AM
