Light Switch OFF But Light Is On - Help! - Electrical - DIY Chatroom Home Improvement Forum
Old 06-23-2012, 09:05 PM   #1
DIY Enthusiast/Renovator
Question
Light Switch OFF but light is on - Help!
I have removed my existing fluorescent strip lights in my kitchen/dinette and installing recessed, but I have a slight problem. I am trying to take power from a three way switch and take it to a light in the back hall. This light in the hall will be controlled only from a single pole switch
Take a look at the attached file for a diagram of what I have going on. I have an incoming 14/2 into a switch box where it is hooked up to a 3-way switch (to control the kitchen/dinette lights). The incoming black is pigtailed to the black of another 14/2 that goes to a light and all the whites are wire nutted together. I have verified the 3-way switches are functioning correctly, but the hall light goes on only when the switch is 'off'.
Any ideas where I went wrong? After flicking the single pole switch to 'on' the breaker trips.
Thanks in advance for the help!
roundbox52 is offline   Reply With Quote
Old 06-23-2012, 09:16 PM   #2
Rewards Points: 6,652
If the breaker trips when you move the switch, that means that you have created a short somewhere. A 3-way switch would have a Traveler, Common & hot connected to each switch. Hot could be Red or Black. You can also have a 3-way Switch leg, if power comes in at the light. Really need pictures on this one.
When and why was the single pole switch added? It would not be in this situation, if the light is controlled by a 3-way, which you show. There is more here than what you are stating.
BTW, the Single pole would be a "Switch leg". When you put in the light, you mis-wired as I stated before. Also, these "quick" clips you used, are they Wago's, or something else?
Old 06-23-2012, 09:19 PM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You have the hot from the 3 way switch tying directly into the fixture.
Old 06-23-2012, 09:20 PM   #4
k_buz's Avatar
Then you have the switch leg coming off the switch and tying into the neutral creating a dead short.
The Following User Says Thank You to k_buz For This Useful Post:
gregzoll (06-23-2012)
Old 06-23-2012, 09:25 PM   #5
k_buz's Avatar
Take the wires from the switch out of the quick connectors. Take the hot out of the quick connector as well. The white (taped black) from the switch goes to the hot. The black from the switch goes to the fixture black.
Old 06-23-2012, 10:03 PM   #6
" Euro " electrician
frenchelectrican's Avatar
Try this diagram this is the same as K_buz mention
Merci,
Marc
Old 06-24-2012, 07:11 AM   #7
Gregzoll - A .pdf diagram is attached - I am controlling a hall light from a single switch which takes its power from a three way switch. The quick connectors are built into the recessed Commercial Electric fixture.
Old 06-24-2012, 07:12 AM   #8
k_buz - Thanks for the help! Works great now! Wow - recessed lighting is so different from those 4' fluorescent fixtures!
Old 06-24-2012, 07:32 AM   #9
No, there is nothing different about the two. They both get hooked up the same. It is just that you wired the switch leg up incorrectly, when you replaced the fixture. Simple mistake.
Old 06-25-2012, 08:27 AM   #10
gregzoll - I was just talking about the difference between the light output and the feel of the lighting - not the wiring.
Thanks though.
The Following User Says Thank You to roundbox52 For This Useful Post:
silversport (06-25-2012)
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 07:25 PM
Replace bathroom light switch with dimmer switch ToddD Electrical 11 05-06-2012 05:58 PM
Mystery Light Switch smokey847 Electrical 3 02-04-2012 10:44 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 09:02 AM
