Light & Switch Not Working - Electrical - DIY Chatroom Home Improvement Forum
Old 01-18-2009, 05:21 PM   #1
Light & switch not working
I've got a light over a bathroom vanity that stopped working a couple days back. I removed the switch and used a voltage detector to test for a hot wire. None of the wires tested hot, so it seems I've got no power going in or out of that switch. All surrounding outlets and lights are working, and I confirmed the voltage detector is working. I'm fairly new to diy and am now at a loss over what to do next.
jgayle is offline   Reply With Quote
Old 01-18-2009, 05:28 PM   #2
joed's Avatar
Rewards Points: 12,872
Push the reset on the GFCI. If that doesn't work then you have a loose connection where ever this switch gets it power. Could be at the fixture.
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 12:17 PM
Two switch in one box: only one working jdtsmith Electrical 12 09-29-2008 01:32 PM
no power going to the light switch baseballfan Electrical 18 09-08-2008 05:35 PM
Light switch not working jathornton1 Electrical 2 04-15-2008 04:13 PM
Light switch not working! jtbel Electrical 4 12-09-2006 06:34 PM
