#1 |
Light switch/light not working
We have one switch in our house that has been acting funny. It is in our walk in closet and sometimes it will turn the light on and sometimes it won't. Any thoughts here?
#2 | |
UAW SKILLED TRADES
Light switch/light not workingQuote:
What kind of light fixture? |
#3 |
Typical toggle switch. It is an overhead "dome" style light on the ceiling.
#4 |
1. loose connection at switch
2. loose connection at fixture 3. loose light bulb 4. Chinese light bulb |
#5 |
Electrical Contractor
5. Bad switch.
-KB Life is uncertain -- eat dessert first!! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#6 |
Licensed Electrician
Is it a fluorescent light? I'm thinking circle-line lamp/ballast. (Round tube type fluorescent)
Not a fan of the new layout.
Answers based on the National Electric Code. Always check local amendments. |
#7 |
Go a meter to check the switch?
#8 |
Ok. What's my plan of attack to fix the problem? Electrical is where I have the least experience.
#9 |
Kill the breaker to that circut.
Remove the switch cover and check the switch with a Volt OHM meter set to OHMs. Just flip the switch on and and off, wiggle the switch when it in the on position. You do not have to disconnect the wires to try this. |
#10 |
Chinese light bulb- God help us all
#11 | |
I don't have a Volt meter. Only a voltage detector. Took the switch cover off. Checked the connections and they were ok. So went ahead and replaced the switch and still no luck. |
#12 |
Turn the power off and replace the switch for 69 cents.
If it doesn't work then, come back for more advice!
Yes I am a Pirate, 200 years too late. "Jimmy Buffett" |
#13 | |
#14 |
Missed that, sorry.
What kind of fixture?
#15 | |
| Display Modes | |
| Hot wires on both sides of switch | RedRumLoki | Electrical | 4 | 11-20-2012 10:37 PM |
| Light in one lighted three-way switch not working | dalepres | Electrical | 2 | 06-26-2012 07:27 AM |
| Ceiling Fan with Light kit - Light not working | aadams | Electrical | 12 | 11-03-2010 07:32 PM |
| Disposal and Sink Light quit working | Sling Blade | Electrical | 2 | 05-25-2009 08:49 PM |
| Light switches not working | marc633 | Electrical | 7 | 07-22-2008 06:34 PM |
