Light Switch Keeps Trippin Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 08-28-2010, 03:28 PM   #1
Light switch keeps trippin breaker
We are trying to hook up this light fixture. We have the fixture hooked up and then wired the two light switches up. White on top Black on bottom. Everytime we turn the breaker on it automatically trips before we do anything.
jrwoods1 is offline   Reply With Quote
Old 08-28-2010, 04:17 PM   #2
Assuming you have this circuit switched, you've probably passed between 400 A and 10,000 A through the switch for one or two cycles of 60 Hz power. It's a few milliseconds.
The switch might be clobbered but carrying this much current is less stressful on the switch than switching this much current.
Depending on how comfortable you are with electricity you can hook up an incand. lamp for troubleshooting purposes and prevent breakers tripping and ruining switches.
Old 08-28-2010, 04:30 PM   #3
Licensed electrician
Rewards Points: 1,272
Unless you wired these switches in a switch loop the white should not connect to the switch. Can you describe the path of the cables and how you made your connections?
Old 08-28-2010, 06:12 PM   #4
floor_whore
Send a message via Yahoo to Aaroncarpet
sounds like a dead short
sounds like you don't have it wired back to the panel right....i just had the same problem....make sure your switches are linear....is the power at the switch or up by the light....2 pole switches are linear so hot power to swith black. switch white pole to lightwire black....the white from the light should go back to the panel...and grounds twisted off......
Aaroncarpet is offline   Reply With Quote
Old 08-28-2010, 08:40 PM   #5
joed's Avatar
Rewards Points: 12,016
We need to know how you made all the connection for this circuit. Sounds like a switch loop where you matched all the colours and are creating a dead short.
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 03:44 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
new light and switch problem please help rebelbull Electrical 1 10-02-2009 07:39 AM
HELP.. trouble adding light to single pole switch RickDel Electrical 13 09-09-2009 11:18 PM
Adding second light switch to an existing light TexasEd Electrical 7 08-15-2008 07:22 PM
