Old 10-29-2007, 02:44 PM   #1
Light Switch Inconsistency
I did a search on my problem with no luck.
We moved into our house this weekend that we have bought and been updating it since Oct 1st. We have noticed that numerous light switches throughout the house do not always work on the first time of being flipped to the 'on' position. It sometimes takes 2 or 3 times before the light comes on.
Has anyone had this problem before? Is this something that will be repaired if I replace the light switches throughout the house?
The house was built in 1989.
Any advice would be highly appreciated.
Dallas is offline   Reply With Quote
Old 10-29-2007, 03:16 PM   #2
Electrical Contractor
It may be the light switch, it may be a loose or illfitting connection in the light.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 10-29-2007, 03:31 PM   #3
UAW SKILLED TRADES
Stubbie's Avatar
You need to test the switch to see if the switched wire is hot in the "on" position.
Are any of these switches 3 - way?
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 10-29-2007, 03:41 PM   #4
Thanks for the replies. I am not sure about the proper terminology. If by 3 way you mean 3 switches on the switch plate then yes. Some of these switches are 3 way and maybe one of them is a 2 way.
I forgot to mention that we are first time homeowners.
Old 10-29-2007, 05:04 PM   #5
Electrician philosopher
My buddy stubbie means by three way.... Does the light switch from more than one location. I got tickled when I read your post, couldn't help myself. I am not laughing at you, I'm laughing with you, I promise!
Andy in ATL is offline   Reply With Quote
Old 10-29-2007, 05:46 PM   #6
joed's Avatar
What type of light. Some fluorescents will have problems if not grounded properly.
Old 10-29-2007, 06:17 PM   #7
UAW SKILLED TRADES
Stubbie's Avatar
Sorry, I guess I forget how much new homeowners have to learn about their homes. I have a feeling that Joe has the right thought on this problem. It would be very odd to have several switches bad at the same time.
Stubbie
Stubbie
Old 10-29-2007, 06:49 PM   #8
It would be "lottery" odd. It will be interesting to see what transpires.
Old 10-29-2007, 07:15 PM   #9
Smile
Turn off the the CB to the circuit you are working on. Check to see if the switches are "stabbed" in the back. If so, wrap the conductor around the actual screws on the switch. Even though "stabbing" is allowed in some areas it is a bad practice. Think about it! As the copper heats up it expands. As it cools down it contracts. Eventually, one ends up with a loose connection and this can cause serious problems. Maybe this will help.
Master Elec./NICET IV FA is offline   Reply With Quote
New light switch burns out dsbutler71 Electrical 12 09-05-2007 08:34 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Light Switch Keeps Tripping Breaker jackiesmom Electrical 23 05-24-2007 03:27 PM
Light switch not working! jtbel Electrical 4 12-09-2006 07:34 PM
