Old 04-07-2010, 12:24 PM   #1
Closed June 29, 2007
light switch help
Two vanity lights in my bathroom are connected to one switch in my bathroom. A second switch next to that switch controls lights over the shower and tub. The second switch works, but the vanity lights are not working. The light bulbs work. and I've tested the wires for power at the switches and I'm getting power. I tried to replace the switch with a new one and it didn't work. I even disconnected the other switch and tried hooking it up to the vanity lights switch and it didn't work. I'm running out of ideas as to what the problem is. The wiring job isn't very good. Nothing is grouned either. Any suggestions?
jcurts75 is offline   Reply With Quote
Old 04-07-2010, 12:36 PM   #2
Just call me Andrew
light switch help
Have you tried another fixture?
Andrew
secutanudu is offline   Reply With Quote
Old 04-07-2010, 12:38 PM   #3
light switch help
i have not tried another fixture because there are two fixtures up there and neither are working right now.
Old 04-07-2010, 12:51 PM   #4
Just call me Andrew
light switch help
Oh - I was thinking it was a multi-light fixture. Do you have a non-contact tester? Test for voltage at the first fixture (the with the switch on and off.
Andrew
Old 04-07-2010, 01:18 PM   #5
Master Electrician
light switch help
More than likely the connection in the wall behind the fixtures has come loose.
brric is offline   Reply With Quote
Old 04-07-2010, 02:32 PM   #6
light switch help
brr...i will have to check that when i get home. Will let you know
Old 04-07-2010, 07:11 PM   #7
joed's Avatar
light switch help
Look for a loose neutral(white) wire. It could be in the back of the switch box or in the fixture.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 04-07-2010, 10:05 PM   #8
Exclamation
light switch help
Aside from the grounding problem, which is critical to be repaired, especially in a bathroom. Did you check if there's a twist button/switch on top of each fixture????!
spark plug is offline   Reply With Quote
Old 04-07-2010, 10:11 PM   #9
Learning by Doing
Leah Frances's Avatar
light switch help
I could have used this advice a year ago.
took down that stupid light fixture that never turned on. From it's mounting position I couldn't see it had it's own on/off switch right on top.
It was ugly anyways.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 04-08-2010, 02:31 PM   #10
Wink
light switch help
Leah frances (Poster #9) I'm speaking of personal experience, where I was called to check out a "Stubborn" Light fixture that used to work in the past...! I did everything in reverse order. Checking for power at the breaker, fixture and pulled the switch to check for power and continuity. Then.. It hit me!! (Literally..) So, I'm sharing my experience with everyone else!!! Some people (like me) learn the hard way!
Tags
electric, light switch
Amana roll out switch light blinking butter99 HVAC 2 04-02-2010 11:19 PM
HELP.. trouble adding light to single pole switch RickDel Electrical 13 09-09-2009 11:18 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 08:52 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 10:02 AM
no power going to the light switch baseballfan Electrical 18 09-08-2008 06:35 PM
