Old 09-10-2011, 12:32 PM   #1
Light switch flashed as ceiling light bulb blew
House is 4 yrs. old. Turned on light switch in laundry room overhead light; the bulb blew and the light switch also sparked but didn't shock me, nor did it trip the circuit breaker. This light fixture seems to need frequent bulb replacements. Is it a wiring issue or switch issue? Is this a fire hazard?
myrrh is offline   Reply With Quote
Old 09-10-2011, 11:41 PM   #2
Check the wiring in both the switch box and light box. Take pictures that would help
jmans8666 is offline   Reply With Quote
The Following User Says Thank You to jmans8666 For This Useful Post:
myrrh (09-11-2011)
Old 09-11-2011, 10:15 AM   #3
Measure the voltage in the socket with the bulb removed.
Is the bulb of too great a wattage for the fixture? More than 60 watts incandescent in an enclosed fixture is enough to at least raise an eyebrow although some fixtures can take a little more.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded.
The Following User Says Thank You to AllanJ For This Useful Post:
myrrh (09-11-2011)
Old 09-11-2011, 11:06 AM   #4
Licensed electrician
Frequent bulb changes can be a signal of a loose connection. Loose connections cause heat. Too much heat causes fires.
myrrh (09-11-2011)
Old 09-11-2011, 11:48 AM   #5
Appreciate all the good information from all who replied. I'll be calling an Electrician tomorrow!
Another concern... is it ok to use the washer/dryer, which are located in this room and are no doubt on the same circuit?
Old 09-11-2011, 06:53 PM   #6
Usually lights are on a different circuit to appliances,
lights vs power.
different !
So yes you can use the dryer and washer.
Dont forget to let us know how it turns out !
dmxtothemax is offline   Reply With Quote
Hunter Ceiling Fan & Light control #27182 slrholmes Electrical 17 11-15-2011 10:33 PM
Ceiling Fan and Light Switch Problem desiboy Electrical 3 03-03-2011 01:09 PM
Proper way to switch a ceiling light. CoconutPete Electrical 6 06-11-2010 08:19 AM
Wiring a Ceiling Fan to a Switch that also Controlls Hot Switch timsarah Electrical 6 03-30-2010 09:14 AM
Adding Ceiling Light To Switch vboz5 Electrical 11 03-14-2009 12:09 AM
