Light Switch Failure Help!! - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-04-2010, 04:55 PM   #16
Rewards Points: 30
Didn't think of neutrals and grounds bonded together in the fan.rex did not mean energized when he said hot he meant they go to the fixture. He has no meter.
daveb1 is offline   Reply With Quote
Old 02-04-2010, 05:34 PM   #17
I picked up a Greenlee electrical kit on my way home. Ill test the wires now.
metalrex is offline   Reply With Quote
Old 02-04-2010, 06:23 PM   #18
b to c and g to f with all grounds together give me power to the outlet!
Old 02-04-2010, 06:33 PM   #19
I'm not getting voltage out of a. My guess ia B powers all. So I'll twist whiyes together, all the blacks and use the remaining wire fof the switches.
Old 02-04-2010, 06:53 PM   #20
Rewards Points: 30
Before you put anything together take your meter and look for a short between white wire E and the bare copper wire in that same bundle
Old 02-04-2010, 07:00 PM   #21
Glad To Be Here
Metalrex, are you installing just common toggle type single pole switches for both the light and the fan?
Pro_DYIer is offline   Reply With Quote
Old 02-04-2010, 08:55 PM   #22
I got it running. Im using a basic toggle switch for the light only. I attached B&C a spare wire, and a black wire from the fan switch. I attached a black end of the toggle switch to the spare wire and the other to the red wire. the other black wire of the fan switch went to A. Everything works now! Thanks, guys.
Old 02-04-2010, 09:13 PM   #23
Glad To Be Here
Glad it worked out for you.
HELP.. trouble adding light to single pole switch RickDel Electrical 13 09-09-2009 10:18 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 09:02 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
no power going to the light switch baseballfan Electrical 18 09-08-2008 05:35 PM
