Old 04-25-2008, 06:57 PM   #1
Light switch from a double socket ?
Hi,
I'm busy laying a new patio and want to put a couple of lights out there. I'm running a piece of armoured cable from the kitchen to the pillars where I want the lights. I haven't a clue how to go about wiring them though.
Can I get a normal light switch to function by connecting it from a double socket plug ?
All advice welcome
Terry Collier is offline   Reply With Quote
Old 04-25-2008, 07:19 PM   #2
Master Of Nothing
mr500's Avatar
what gage cable are you running? What kind of lights are they? Any plugs out there as well? Will need a GFi outside. Normal switch can be wired in to work.
Im Not An Electrician...But I Did Stay At A Holiday Inn Express Last Night!!
mr500 is offline   Reply With Quote
Old 04-25-2008, 08:22 PM   #3
joed's Avatar
Where in the kitchen are getting the power? You can't get it from any of the receptacles located in the counter area. The kitchen counter receptacles are required to serve only the kitchen counter.
Old 04-25-2008, 08:30 PM   #4
Thanks guys,
I haven't got the cable yet. The type of lights I was thinking of were just 40w outdoor lights (not low voltage)
I have a a choice of 3 double sockets from which I can take the supply. 2 in the kitchen (behind cupboards - used for tumble dryer at the moment) and 1 double socket in an adjoining spare room.
Any thoughts ?
Old 04-25-2008, 08:31 PM   #5
Master Of Nothing
mr500's Avatar
Ughh did not see the kitchen feed.
Old 04-26-2008, 11:39 AM   #6
Licensed Electrician
jrclen's Avatar
Originally Posted by Terry Collier View Post
Hi,
All advice welcome
Will the cable be run above ground or underground? You can feed the circuit from a receptacle outlet circuit, but not from the kitchen small appliance circuits. You can feed a switch from the receptacle and then continue to the lights. Try to describe your project a little more to help us picture it.
jrclen is offline   Reply With Quote
Hot light switch - how dangerous, and what to do? maximizer Electrical 12 12-29-2011 11:19 PM
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 10:34 PM
can a power surge flip a light switch? bluebee1314 Electrical 9 07-13-2009 03:33 AM
Adding one recessed light to exsisting switch... JayBird Electrical 1 04-03-2008 08:32 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
