Old 10-22-2008, 02:00 PM   #1
Default Light Switch to Detached Garage - Grounding Issue
I have a detached garage with its own subpanel. The garage has an exterior light fed from this panel, controlled by 3-way switches in the garage and house; the 3-way in the house shares a plastic 2-gang box with another switch that controls the hallway lighting. My question is whether or not this 3-way switch in the house is properly grounded:
The garage sub has its own grounding electrode and there are no metallic connections between the house and garage (other than the sub feeder and the wires for this switch, which are buried in separate PVC conduits). The feeder ground is bonded to the ground in the main panel, and is properly isolated from neutral in the sub. There is an EGC pulled in the switch conduit which is bonded directly to the ground bar in the sub (both conduits enter directly into the panel, the switch wiring is spliced inside) - the other end is tied to the metallic J-box that terminates the conduit inside the house. From that box, 14/3 Romex completes the run to the switch, and the EGC in that cable bonds the switch yoke to the J-box. This switch is NOT bonded to the other switch in the wall box, which is fed from the main panel within the house. It seems to me that this creates the possibility for these two switches to be on different ground planes if the subpanel or the feeder wiring were to become damaged. I believe the correct thing to do would be to tie the adjacent switch yokes together and break the bond with the garage panel at the J-box (such that the EGC coming from the garage would be left "dead-ended" to protect the wiring in the conduit) but I'm having a hard time finding anything that either supports or prohibits this approach in the NEC. Garage subs are a common "add-on", so I'd imagine this issue must come up frequently along with them; can anyone confirm the correct approach to this?
smitty286 is offline   Reply With Quote
Old 10-22-2008, 02:17 PM   #2
My License Ain't 4 Sale..
I cannot give a code reference at the moment, but it has always been my practice to tie all grounds in every box together. The goal is to establish a grounding "network", a level of grounding redundancy. Someone here will be along to state the code article I'm sure, but in any case, you'd be right to tie the grounds together.
More On This Topic
If you want to install an outdoor fan, you should wire a nearby switch so you can control it easily. There are various types of switches that you can use, but what matters most is that you are using components that are safe for outdoor use. Read More »
Hi, this is Jon on behalf of Expert Village. In this video clip we'll be locating our power shut off. Before we can start taking down our old light we need to make sure that the power is shut off so we don't get electrocuted. The first thing we need to... Read More »
Hello! My name is Judy Williams on behalf of Expert Village and today we’re talking about different ways to decorate your living room on a budget. Lighting in a room is very important. This old floor stand lamp, you can see, does not have a shade... Read More »
Patching the aluminum siding on your home can be difficult because of how the panels interlock. It is possible to fix the siding with a little effort, some time and good weather. Read More »
Hi, this is Jon, and in this clip we'll be gluing the threshold. At the bottom of our door we have have our threshold, and before we install our door we need to put some construction adhesive underneath the threshold, and that's going to help hold that... Read More »
Grounding light box n0c7 Electrical 10 10-06-2008 05:20 PM
Problem changing light switch grgryl Electrical 14 08-10-2008 03:26 PM
Grounding for detached all-metal garage geeswanie Electrical 3 07-03-2008 09:31 AM
Detached Garage Sub Panel Grounding Q integlikewhoa Electrical 13 01-01-2008 08:22 AM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 04:53 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
