Light Switch With Cracking/popping - Electrical - DIY Chatroom Home Improvement Forum
Old 03-01-2009, 01:01 PM   #1
Rewards Points: 113
light switch with cracking/popping
I have several light switches that have a small but noticable cracking sound of an arc when I turn them on. I have eliminated loose connections as the cause. Is this a hazard to be replaced immediately or at some point will the switch just stop working?
Captflx is offline   Reply With Quote
Old 03-01-2009, 01:12 PM   #2
If you can tease the switch slowly open and prolong the arc sound I think they are bad switches that have lost their "snap action."
Motor loads should make the worst arcs.
Old 03-01-2009, 01:15 PM   #3
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
I would consider replacing them. The sound may be normal when the switch first makes contact, especially when it's turned on softly or under significant load.
Maybe consider getting some good quality switches vs 39 cent ones.
wirenut1110 is offline   Reply With Quote
Old 03-01-2009, 01:20 PM   #4
Electrician
I agree, if the switch sounds like it's popping or sizzling, I would replace them. Even the good quality switches are only a couple bucks a piece.
EBFD6 is offline   Reply With Quote
Old 03-01-2009, 01:24 PM   #5
Radio noise gives a measure of arcing.
An AM radio tuned between stations and held near the switch should give some relative indication of the arcs from a known good switch compared to the ones you have.
Old 03-01-2009, 04:15 PM   #6
Rewards Points: 113
light switch cracking/popping
Thanks.
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 12:17 PM
no power going to the light switch baseballfan Electrical 18 09-08-2008 05:35 PM
Adding second light switch to an existing light TexasEd Electrical 7 08-15-2008 06:22 PM
Problem changing light switch grgryl Electrical 14 08-10-2008 01:26 PM
