Light Switch For Chandelier - Electrical - DIY Chatroom Home Improvement Forum
Old 07-11-2011, 09:41 PM   #1
Light switch for chandelier
Can I use a regular 15A 3-way switch for a chandelier that draws 600W (15 40-watt bulbs)? I would prefer to not spend the extra $ for a dimmer
Boz1 is offline   Reply With Quote
Old 07-11-2011, 10:23 PM   #2
Just call me Andrew
Rewards Points: 1,020
Yes, but you do not need a 3-way switch for it. If you have a 3-way laying around, connect one black wire to the COMMON terminal, and the other to one of the other terminals. If the switch works as planned, leave it. If you wired to the wrong terminal, the switch will be backwards (down--on, up--off).
Nut all whites together.
Andrew
secutanudu is offline   Reply With Quote
Old 07-11-2011, 10:39 PM   #3
Thanks, Andrew.
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 07:25 PM
HELP.. trouble adding light to single pole switch RickDel Electrical 13 09-09-2009 10:18 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 09:02 AM
no power going to the light switch baseballfan Electrical 18 09-08-2008 05:35 PM
