Light Switch Breaker Trip - Electrical - DIY Chatroom Home Improvement Forum
Old 02-16-2012, 06:13 PM   #1
I recently removed a wall going from my living room to dining room. In the process I had to move a light switch. The original wiring wasn't long enough so i put a junction box in and spliced wires onto it. The light switch is now tripping the breaker when its flipped and I can't find the problem. The power source is 12 2 and the wiring going from the fixture to the switch is 12 3. Looking for any suggestions as to where to look. Thanks
kremic30 is offline   Reply With Quote
Old 02-16-2012, 06:29 PM   #2
Licensed electrician
Rewards Points: 996
It might help to know what connections you made and what the original connections were.
Old 02-16-2012, 06:31 PM   #3
what do you mean by connections
Old 02-16-2012, 06:32 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
So what wires are on the switch and what wires are connected in the junction box?
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-16-2012, 08:21 PM   #5
It's easy enough to check if you have wired the switch between hot and neutral or hot and ground. If so, your switch is pretty much ruined.
Old 02-16-2012, 09:13 PM   #6
Rewards Points: 582
seeing is believing send a picture...please
Old 02-16-2012, 10:36 PM   #7
Rewards Points: 77
In reference to the 12/3 are there any other switches besides the one you moved that control the fixture?
Mikenra is offline   Reply With Quote
Old 02-16-2012, 10:45 PM   #8
will the junction box be accessible when you are finished with the remodel?
Old 02-16-2012, 11:12 PM   #9
UAW SKILLED TRADES
Stubbie's Avatar
Anybody have a bad feeling ......
Stubbie
The Following User Says Thank You to Stubbie For This Useful Post:
ben's plumbing (02-17-2012)
Old 02-16-2012, 11:18 PM   #10
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Twisted wires and scotch tape?
rrolleston is offline   Reply With Quote
The Following User Says Thank You to rrolleston For This Useful Post:
Old 02-17-2012, 12:54 AM   #11
Rewards Points: 264
Tape! We don't need no stinking tape.
a_lost_shadow is offline   Reply With Quote
Old 02-17-2012, 07:55 AM   #12
jbfan's Avatar
Rewards Points: 138
Duct tape!
It hold anything!
jbfan is online now   Reply With Quote
3 way switch -OK to drop down neutral like this to light through switch box via 12/3? darlingm Electrical 9 12-22-2011 03:48 PM
220 volt breaker switch raiden22003 Electrical 13 09-23-2011 01:05 PM
Newbie - fixing a switch and adding a light telechick Electrical 3 09-14-2011 09:59 PM
new light and switch problem please help rebelbull Electrical 1 10-02-2009 07:39 AM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 08:52 PM
