Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 03-06-2011, 01:40 AM   #1
Light switch
Was gonna install light switch it had 3 wires coming from it. Had a red wire on left side by itself and black and white on other side. Any help will do
Jeblack2031 is offline   Reply With Quote
Old 03-06-2011, 06:56 AM   #2
That is a 3-way switch, there is another switch somewhere that operates the same light/fixture. The red is the common, and goes on the black terminal of a 3-way, Blk/wht go on the other two, but you may need to switch them(blk/wht) to get things to work correctly.
Old 03-06-2011, 08:41 AM   #3
I=E/R
a7ecorsair's Avatar
Before you start disconnecting wires, look closely at the switch screws. One screw is a common. Depending on how old the switch is or who made it, this common screw should be black and the other two screws gold. Get a three way switch and make sure you connect the wire from the common on the old switch to the common on the new switch.
Bills wire color description may or may not match your setup.
a7ecorsair is offline   Reply With Quote
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
HELP.. trouble adding light to single pole switch RickDel Electrical 13 09-09-2009 10:18 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 09:02 AM
no power going to the light switch baseballfan Electrical 18 09-08-2008 05:35 PM
