Light Switch With 5 Wires, Black, White, Red, Wtf? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-24-2011, 07:19 AM   #1
This is a light switch in my basement, it only controls one light out of the 4 down there, I need to replace this switch, it sparks badly and heats up fast, I've never seen anything like this though, what kind of switch is this and whats up with the red wire??
Light Switch With 5 Wires, Black, White, Red, Wtf?-11.jpg   Light Switch With 5 Wires, Black, White, Red, Wtf?-22.jpg
ts46176 is offline   Reply With Quote
Old 07-24-2011, 08:15 AM   #2
I assume the red wire would be a traveler. is the switch at the top of the stairs? and is there another switch somewhere near that operates the same fixture?
and is that knob and tube coming into that box?
1910NE is offline   Reply With Quote
Old 07-24-2011, 08:27 AM   #3
Electrician
SD515's Avatar
Rewards Points: 504
I’ve not seen a switch like that before, but I don’t think it’s a 3 way switch. Looks like either power comes in on the black on the right with a constant feed to the black on the left and goes out the red when the switch is on, or comes in on the red and leaves the 2 blacks when the switch is on. The whites could be a constant connection via the yoke.
Kyle
Old 07-24-2011, 09:01 AM   #4
Household Handyman
Rewards Points: 1,408
I think it's time you identify each wire as to which is the line feed, line neutral, the load feed, and the load neutral. In you second photo the red wire appears to be tied into a black wire so now I'm wondering if the red is not tied into a black "feed" wire which goes back to what "SD515" said, it could be feeding from the red wire.
Old 07-24-2011, 09:05 AM   #5
Household Handyman
Geez, I had to go back and look at the photo's really close again. Now it appears that the neutral is switched, the black wire at the top is "passed-through" via the little bus bar thingy, and the red is just connected to a screw which does not appear to be connected to anything. But I still have the question as to which way the feed runs and what is the red wire for, and/or is it "HOT".
Old 07-24-2011, 09:16 AM   #6
Electrician
SD515's Avatar
Rewards Points: 504
My first guess is that power comes to the switch via the cable on the right. Feeds through the ‘busbar’ out the black, which in turn feeds the octagon constant power. The red being switched, to control the white romex cable at the octagon, because obviously the white romex was added later. My guess is it’s the light someone added later.
Just a guess. And you’re right Thurman, the wires need to be identified before proceeding further.
Kyle
Old 07-24-2011, 09:30 AM   #7
that is the one and only switch for that light, and thats an old knob, none of it is live or connected anymore
Old 07-24-2011, 09:37 AM   #8
Ok, I just checked with a volt meter, the top 2 blacks are a constant hot, the 2 whites never have power, the red wire becomes hot when the switch is flipped on
Old 07-24-2011, 09:29 PM   #9
" Euro " electrician
frenchelectrican's Avatar
Just give you a head up I have see it before that is a surface mounted switch something you see in the Barn or surface mounted cables { those item is getting super rare now I know one company still make it but getting limited } { that in NA side but in France it pretty common item we get them pretty frequent }
Merci,
Marc
Old 07-24-2011, 09:48 PM   #10
I=E/R
a7ecorsair's Avatar
This is a surface mounted switch and I sold quite a few when I was working in the family hardware store in the early '70s. As French said, they are quite rare now.
If the flash were turned off and the focus a little better, you'd see this works as mentioned above. The red is the switched hot. The pass through is also connected to the switch. The whites are connect to the switch strap similar to the the white being on the shell of a porcelain fixture.
a7ecorsair is offline   Reply With Quote
The Following User Says Thank You to a7ecorsair For This Useful Post:
frenchelectrican (07-24-2011)
Old 07-25-2011, 05:22 AM   #11
Any idea where I can get one from? Or Is their a way to rewire it to make it fit a modern switch?
Old 07-25-2011, 07:44 AM   #12
I=E/R
a7ecorsair's Avatar
Unless you could find one in a second hand store, you may have to resort to a new switch. The problem will be wire length. These were wired-to-fit so there is no extra length to use inside a switch box. If you could pull a new cable to the light and mount a handy box about two inches to the right then you'd be OK
Old 07-25-2011, 08:49 AM   #13
Remodeler
Rewards Points: 330
deleted
iamrfixit is offline   Reply With Quote
Old 07-25-2011, 07:35 PM   #14
So in theory, if I connect the 2 whites with a wire nut, pig tail wire the 2 blacks to the new switch on the top terminal and connect the red wire to the bottom terminal it should work then? (provided i have enough wire length)
Old 07-25-2011, 07:38 PM   #15
I=E/R
a7ecorsair's Avatar
You got it
Switch Junction box has 3 sets of 3 wires. Can't get dimmer to work knockout Electrical 14 01-10-2015 09:08 AM
can switch work for two different outlets? jlmran Electrical 8 02-10-2011 12:31 PM
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 02:17 AM
Installing of SwitchLinc Dimmer (2476D) dlp_710 Electrical 8 08-07-2009 01:31 PM
Hunter Fan Dual Switch Wiring Configuration Help schierle Electrical 2 03-29-2009 08:00 PM
