Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 03-02-2013, 02:04 PM   #1
Light switch
I have 2 hall lights that are controlled by 3 light switches. One at the bottom of the stairs and 2 at the top of the stairs. If I use the light switch at the bottom of the stairs to turn on the light and then turn it off at the top of the stairs I can't turn it back on with the light switch at the bottom of the stairs or sometimes not the other one upstairs. There is no consistancy that I have found with the position of each of the switches either up or down. I have taken the face plates off the switches and there doesn't seem to be any damge or loose wires. The light bulbs are CFLs so no filiment intermittently coming in contact. I am at a loss of what could be wrong. I don't believe it is any of the switches. Any advice is appreciated.
ngavazzo is offline   Reply With Quote
Old 03-02-2013, 02:20 PM   #2
Rewards Points: 6
Is this a new issue?
Has any work been done to that circuit recently?
Have you tried a regular incandescent bulb to see if it changes anything?
djlandkpl is offline   Reply With Quote
Old 03-02-2013, 02:37 PM   #3
Licensed electrician
Rewards Points: 1,054
One or both of the switches are miswired. A traveler is transposed with a common.
Old 03-02-2013, 02:42 PM   #4
Rewards Points: 12,914
http://www.bing.com/images/search?q=...electedIndex=0
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Hot wires on both sides of switch RedRumLoki Electrical 4 11-20-2012 10:37 PM
Replace bathroom light switch with dimmer switch ToddD Electrical 11 05-06-2012 06:58 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 08:52 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 10:02 AM
