Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 12-19-2011, 10:33 AM   #1
Light Switch
MB ceiling light quit working. Replaced bulbs, then light then light switch. Still doesn't work. Tested wire at switch, no power. Circuit breaker turned off shuts power to other switches and outlets off and back on when turned on. Thought if no power to one appliance would shut power to other appliances on same circuit. Am I missing something?
hdaleshelton is offline   Reply With Quote
Old 12-19-2011, 11:36 AM   #2
Mad Scientist
Could you clarify your question? Are you confused because you don't have power at the light swtich, despite still having power to the rest of the circuit?
How are you testing for voltage at the switch? Voltmeter or non-contact voltage detector? If using a voltmeter, what two points are you measuring between?
McSteve is offline   Reply With Quote
Old 12-19-2011, 09:19 PM   #3
Light Switch
Checked wiring again. The ground had come loose and I think it came into contact with one of the other wires and shorted out. Rewired it again and everything works. Thanks for responding.
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 07:25 PM
Pilot Light Switch? dweeter Electrical 3 11-04-2011 08:44 PM
HELP.. trouble adding light to single pole switch RickDel Electrical 13 09-09-2009 10:18 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 09:02 AM
