Light Stopped Working - Electrical - DIY Chatroom Home Improvement Forum
Old 01-10-2007, 02:49 PM   #1
We have a light in our bedroom that just stopped working. We replaced the bulb and still nothing. There's no loose wires to the switch. There's no blown circuit. How can I figure out what's wrong? I have a voltometer and there's power to the switch. Could it be something as simple as needing a new switch? I don't know very much about wiring and I've spent hours trying to figure out what's wrong. Any suggestions would be greatly appreciated.
gershon is offline   Reply With Quote
Old 01-10-2007, 02:52 PM   #2
it could be the light fixture need to be replaced... if you can use tester to test the wire at the light fixture ... if it has power... then it is indeed your light fixture is a goner...
KUIPORNG is offline   Reply With Quote
Old 01-10-2007, 02:54 PM   #3
Thanks, I tested the light fixture. There's no power to it.
Old 01-10-2007, 02:56 PM   #4
then you can tested the the wires at the switch... the two wire connectted to the switch, one is income, test the outcome, see if it is on and off according to the switch position, hope you tested the switch is a goner... otherwise, you have a bigger problem...
Old 01-10-2007, 03:04 PM   #5
Electrical Contractor
I have ran into a lot of fixtures that were overlamped and actually burned wires off underneath the fixture. Make sure power is off and remove fixture to check condition of wires. (If you have already eliminated the switch)
terrynistler is offline   Reply With Quote
Old 01-10-2007, 08:03 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
How did you check power at the switch? Hot to ground, or hot to neutral?
Possibly there is an open neutral ahead of this on the circuit. You will read normal voltage to ground but not to neutral.
If the switch is just a switch loop you will never find it at the switch box.
Ice maker stopped working bragl01 Appliances 5 10-30-2015 06:56 AM
Halogen motion sensor light stopped working, Incandescent still works keyser soze Electrical 6 05-29-2007 08:53 PM
Light switch not working! jtbel Electrical 4 12-09-2006 06:34 PM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 07:11 PM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 06:02 AM
