Light Socket Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 07-26-2012, 09:58 PM   #1
light socket problem
I have power to the light socket but no light ....tried pulling tab even hooked up the socket remotely and works fine any ideas???
mike0179 is offline   Reply With Quote
Old 07-26-2012, 10:14 PM   #2
kevinp22's Avatar
we need more detail and/or pics to be of any help to you
you mentioned power to the socket, but the socket must also have vacuum tube resister (aka bulb )
kevinp22 is offline   Reply With Quote
Old 07-26-2012, 10:20 PM   #3
Yeah sorry I don't live there or I would take a pic...the tester shows power in the socket and we removed the socket hooked it up to a extension cord and had light....driving me crazy..haha
Old 07-26-2012, 10:36 PM   #4
kevinp22's Avatar
if by tester you mean one of those non-contact testers they are not reliable for precion testing. if yiou have a loose neutral it might still show voltage but no cigar for lighting your lamp. my brothers house had a loose neutral. non contact tester registered voltage, multimeter only registered 78 volts. light didnt work
if you are using a multimeter, what is voltage reading
Old 07-26-2012, 10:51 PM   #5
Yeah it was a non contact fluke tester....I will check it with a meter tomorrow ...thanks for the help
The Following User Says Thank You to mike0179 For This Useful Post:
kevinp22 (07-26-2012)
Old 07-26-2012, 11:38 PM   #6
dmxtothemax's Avatar
Rewards Points: 5,098
If you tested at the active terminal and received a positive result !
And you still have no light !
Then your neutral line is faulty !
EASY STUFF !
dmxtothemax is offline   Reply With Quote
Old 07-27-2012, 06:34 AM   #7
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Verify the lamp is good.
Old 07-29-2012, 12:21 AM   #8
Thanks everyone....now I put a meter to it and from ground to the socket is 124 volts ....does this mean a bad neutral wire....ans if so what is the fix? ??
Old 07-29-2012, 02:11 AM   #9
Check the wires behind the light socket,
for loose/broken wires.
If no joy there,
Go to any j boxs in between light socket and switch.
ditto !
Check wires behind light switch
ditto!
Still no joy check panel.
If still nothing ,
you have a broken cable somewhere.
Old 07-29-2012, 02:14 AM   #10
Check wires for loose connections-
1 - behind light socket .
2 - any j boxs .
3 - behind switch .
4 - Panel .
If still nothing found,
you may have a broken cable somewhere.
Old 07-29-2012, 02:29 AM   #11
Master Electrician
You have to check from neutral to hot for the 120 at the socket.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
ceiling light problem al gilliland Electrical 0 11-15-2011 05:05 PM
IC rated 6" recessed light socket depth barlav Electrical 15 04-08-2011 04:30 PM
Outdoor Sensor Light Problem Chadi Electrical 2 07-04-2010 11:42 AM
Another motion sensing light problem Steelhead Electrical 6 12-24-2008 10:50 AM
Weird Problem with new light.... MRTOWNDRO Electrical 8 12-21-2008 05:00 PM
