Light Receptacle Vs. Switch Test Device - Electrical - DIY Chatroom Home Improvement Forum
Old 03-23-2012, 05:43 PM   #1
Rewards Points: 1,062
Question
light receptacle vs. switch test device
i need to install some wall and ceiling light boxes before i hang drywall.
before i hang drywall, i want to test and make sure all the wiring is done right.
however, one thing i DO NOT want to do is have to actually connect the lights in that process. why? one simple reason: ceiling and wall fixtures are P.I.A. to keep in place physically while wiring and i don't wanna have to do it more than once, i.e. after the drywall is hung. because, unlike recessed lighting, the box is not attached to the fixture and someone needs to hold the fixture while the wiring is connected, i.e. another pair of hands because you can't leave it suspended by the fixture wires, they won't support the weight of the fixture but, even if they did, it would be inconvenient to splice tight wires.
so what i am looking for is an lighing box test device with a lightbulb or some sort of indicators that you would preferably just plug the wires in (while the circuit is disconnected) and test the switch and that is light enough that it can be suspended without wiring into the wall.
i hope you are getting my point. i just installed a box for the vanity light in my bathroom and i had to clamp the light to the stud to hold it in place and then wire it together to test that the light and switch are connected properly. i don't like the system because the fixture wires are hardwired to the housing. there are fixtures that are better designed that have a light socket that gets wired separately and then the heavy fixture just gets plugged into it. one example are Broan ceiling fans, beautifully designed. but most lights are not like that, i.e. are hardwired to the housing, which i consider downright stupid design
Old 03-23-2012, 05:48 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
1) buy a cheap white, plastic "keyless" fixture, wire it with a hunk of romex (ignore the ground in the romex), and spice your fancy testing device to the wires at your switch boxes
2) use a volt meter or "tic tester"
The Following User Says Thank You to k_buz For This Useful Post:
amakarevic (03-23-2012)
Old 03-23-2012, 05:51 PM   #3
Wink
sounds like a plan. thanks
Old 03-23-2012, 05:59 PM   #4
k_buz's Avatar
I should have said
"and spice your fancy testing device to the wires at your switched boxes"
Old 03-23-2012, 06:15 PM   #5
also, why not just wire a power outlet in every box temporarily for testing and plug something in before flipping the circuit on, to avoid getting in contact with hot screws on the side
Old 03-23-2012, 06:15 PM   #6
Licensed electrician
Rewards Points: 1,038
Try one of the Leviton #55
http://www.google.com/search?q=pigta...w=1153&bih=580
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 05:28 PM
2 Wires in to light, 3 Wires out, no juice on the switch prytoo Electrical 4 11-28-2011 06:24 PM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-09-2011 12:00 AM
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 03:17 AM
wiring receptacle form light switch olazu Electrical 8 12-03-2009 10:10 PM
