Light Not Turning, Electricity Seems Present - Electrical - DIY Chatroom Home Improvement Forum
Old 07-12-2015, 07:14 PM   #1
Rewards Points: 58
Light not turning, electricity seems present
Hi Everyone
First, I know nothing about electricity.
I have a chandelier with 6 small lights in it. There is one switch on the wall. The light does not turn on anymore.
Today, I installed a new switch and tested the current when the light is on. When the switch is on, there is current running through the black wire attached to the top of the switch. I also unscrewed one of the small lights and tested the current in socket--there is also current there.
So I don't understand why this light won't turn on anymore when there seems to be current at both points.
Any ideas (put in layman's terms) would be greatly appreciated!
Paul
Paul-NYS is offline   Reply With Quote
Old 07-12-2015, 07:24 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
have you replaced at least on of the bulbs with a known good bulb?
Old 07-12-2015, 07:33 PM   #3
DIY staff
Rewards Points: 7,174
You need power---and a neutral wire that works---did you test from the power wire to the neutral or from the power to a ground (like the box)?
Old 07-12-2015, 07:35 PM   #4
Rewards Points: 58
re: Light not turning, electricity seems present
Yes, I tried a new bulb with a few of the sockets.
It is a fairly new townhouse--built in 2004. So the general wiring should be fine.
Paul
Old 07-12-2015, 07:39 PM   #5
Rewards Points: 58
That is something that I wasn't sure of actually. There is one black wire attaching to the right top side of the switch. And a second black wire attaching to the bottom of the right side of the switch. However, there is no third wire, which I am assuming to be the ground.
When the light switch is in the on position, there is current in the top wire. And I don't think there was current in the bottom wire, when on.
Paul
Old 07-12-2015, 07:40 PM   #6
Rewards Points: 14,026
What are you checking it with?
To check a switch you should be shutting off the breaker to that circut, disconnect one wire on the switch and checking OHM's not voltage.
Old 07-12-2015, 07:40 PM   #7
nap
You talking to me?
nap's Avatar
neither wire attached to the switch is a neutral.
Old 07-12-2015, 07:44 PM   #8
Rewards Points: 58
I got a Commercial Electric voltage detector from Home Depot that works on live wires and non-contact (through the outside of the wire).
Paul
Old 07-12-2015, 07:45 PM   #9
Rewards Points: 58
The lack of a neutral/ground will cause it to fail?
Paul
Old 07-12-2015, 07:48 PM   #10
nap
You talking to me?
nap's Avatar
Paul
sorry for the quickie post. All I meant was that the neutral is not attached to the switch but if this light ever worked, there is a neutral at the fixture from somewhere.
so, to start with:
how many wires in the switch box?
what color is each of them?
what are they connected to?
Old 07-12-2015, 07:49 PM   #11
Waste of time trying to trouble shoot with that.
Need a real volt OHM meter.
Even a cheap $15.00 unit will work.
Old 07-12-2015, 07:50 PM   #12
Rewards Points: 3,396
At the fixture. Check from the post in the center (hot) to screw shell ( neutral)
If you don't have voltage but then check center post to fixture metal (ground) and have voltage then you lost your neutral
ritelec is offline   Reply With Quote
Old 07-12-2015, 07:56 PM   #13
Rewards Points: 58
so, to start with:
It did work previously. Prior to it not working, it did flicker a little.
There are three switches in the box for three separate lights. The other two have very slightly different switch units. So the box is very crowded and its hard to see/untangle wires. The other two work fine.
However for the problem switch, there are only two wires connecting to it (they are black) and I didn't see any other loose wires that could be a third.
The problem is that I am home now and not at the townhouse where the problem is.
Paul
Old 07-12-2015, 08:01 PM   #14
Rewards Points: 58
At the fixture, the center was definitely registering with current, but I did not check the screw shell.
So if the center of the fixture is registering with current and the screw shell is not, then the problem is that I lost the ground wire?
Pau
Old 07-12-2015, 08:01 PM   #15
nap
You talking to me?
nap's Avatar
the listing of the wires is pretty important.
did you do anything immediately prior to the fixture not working?
Recessed Light Bulbs Keep Turning Off and On VinnyBags Electrical 14 06-10-2013 10:41 AM
Outlet works but 3 light switches "die" after turning off mors Electrical 9 11-10-2012 11:35 AM
Delay when turning on light switch Kalquaro Electrical 10 05-02-2012 12:27 AM
Turning pilot light off jmcs23 HVAC 5 06-17-2007 08:38 PM
