Light Not Turning On - Electrical - DIY Chatroom Home Improvement Forum
Old 07-25-2011, 11:27 PM   #1
light not turning on
About half the lights in my house went out after I changed the light bulb on a "tricky" fixture. I found the tripped breaker and flipped it back on. Now all of the lights will come on, EXCEPT the "tricky" one, which seems to have been the source of the initial trip. What should/can I do? Is this a serious problem?
stairway83 is offline   Reply With Quote
Old 07-26-2011, 06:50 AM   #2
Rewards Points: 1,540
You need to test the voltage between hot and neutral at the light fixture and also going back along the route of the circuit back to the panel. Be sure that the breaker in question also has the 120 volts hot to neutral (for breakers the neutral is over on the terminal strip where all the white wires come together).
AllanJ is online now   Reply With Quote
Old 07-26-2011, 02:50 PM   #3
Ron Paul 2012
Voltage Check than look to see if the light in question has a ballast.
HandymanCA is offline   Reply With Quote
How many wires can be tapped into a light fixture? JayBird Electrical 6 07-11-2011 02:44 PM
Ceiling fan light kit duhtroll Electrical 10 06-21-2011 02:29 PM
Dual-brite motion detector light to operate second light? downunder Electrical 2 09-10-2010 03:48 PM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 02:44 PM
Need to replace can light with standard light Woodcutter Electrical 3 02-29-2008 07:06 AM
