Light Noise - Electrical - DIY Chatroom Home Improvement Forum
Old 04-07-2012, 01:09 AM   #1
Rewards Points: 83
light noise
i wired a outlet so I could plug in a strip of LED lights that are able to run in different modes (flash, fade, different colors, etc) When I turn the LED lights on, the stereo, that is plugged into a different circut, has static that goes with the tempo of the lights. When I turn the lights off there is no static. What gives?
rodsteryz is offline   Reply With Quote
Old 04-07-2012, 09:32 AM   #2
seansy59's Avatar
Rewards Points: 258
To start off, I have a LED scrolling sign, LED open sign, neon clock, cell phone charger and a fluorescent light that all creates interference with my am/fm radio or CB radio. Its usually RF interference, since most of the stuff today is made with such low quality components, they leak RF signals.....
This doesn't mean that you don't have an electrical problem though (poor grounding, or reversed hot/neutral, that could cause a similar problem, or worse, an actual hazard/danger).........a sign does show though that when you turn them off, it stops. Do the lights operate on low voltage? (Adaptor/Transformer for the LED's) If so, this is probably the source of interference.....
Did you double check your wiring for your self installed outlet? I suggest getting a tester to test for the correct connections, and a multimeter to test the voltage......
seansy59 is offline   Reply With Quote
Old 04-07-2012, 09:54 AM   #3
joed's Avatar
Rewards Points: 12,000
Interference from the LED controller. Not much you can do other than try a different brand of LED. It's a cheap controller with no noise suppression.
Old 04-07-2012, 09:58 PM   #4
Rewards Points: 83
Here is what I got.
http://www.amazon.com/dp/B0040FJ27S/...60_cs_sce_dp_1
I used them in another part of the basement and they work good with no problem. i also checked the outlets with the 3 light tester and it says it is wired correctly.
Old 04-07-2012, 10:38 PM   #5
Rewards Points: 6,652
You could try one of these http://www.theenergydetective.com/in...d-noise-filter Even though it is for the TED MTU, it should work with your LED lighting. Just follow the directions as stated in the link.
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 11:40 AM
Light clicking noise in fan: fix? Drywallhelp Appliances 3 08-14-2011 10:15 PM
Rattling Noise from Roof when windy drgillian Roofing/Siding 3 02-18-2011 10:05 AM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 09:19 PM
