Light Keeps Tripping The Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 05-28-2012, 07:34 AM   #1
Light keeps tripping the breaker
Hi,
I recently bought and installed an Ikea Gasgrund light (http://www.ikea.com/sg/en/catalog/products/20173943/), but whenever I plug the wires into it, my circuit breaker trips. However, if I plug the wires into a painters light instead (over the mounting of the IKEA light), it works fine. Does this mean the problem is most likely in the circuitry of the IKEA light fixture?
Any help/advice would be greatly appreciated. Thank you,
-Michael
bergmanmh is offline   Reply With Quote
Old 05-28-2012, 07:49 AM   #2
From your description, something is wrong with the fixture. Check the bulb sockets for broken or bent parts, and wires for damaged insulation.
Old 05-28-2012, 08:27 AM   #3
Rewards Points: 1,520
Are you sure you are putting the power wires into the right socket slots?
Looks like power wire goes into L, ground into middle, and neutral into N. You can't always rely on the wire colors in your feeder cable. Do you have a test light or volt meter to check?
bob22 is offline   Reply With Quote
Old 05-28-2012, 10:40 AM   #4
Thanks for the replies. I checked the wires, but they were correct (never hurts to double check though). I inspected the fixture, but didn't see anything obviously wrong. I ended up just swapping it out for a different fixture and everything is working now.
Old 05-28-2012, 04:48 PM   #5
So almost certainly it was the fixture, unless while you changed out the fixture you also changed something else. Think carefully!
Old 05-28-2012, 07:44 PM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 766
First off....that is one ugly light.....sorry....but it's just ugly....
Ok....topic at hand....
What kind of bulb?
Is the ckt that is tripping on an AFIC?
What is a painters light?
ddawg16 is online now   Reply With Quote
Old 05-28-2012, 11:16 PM   #7
" Euro " electrician
frenchelectrican's Avatar
AKA portable 300 / 500 watter quatz luminarie
That what some people call them painter light ( the painter verison will use frosted lens to reduce the glare.)
Merci,
Marc
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 07:09 AM
Garage Fridge Tripping Breaker in Cold Weather aaronjwood Electrical 10 12-24-2010 07:47 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 07:42 PM
Arc Fault Break Tripping when any light switch turned on elab1 Electrical 60 11-20-2009 02:24 PM
