Light Keeps Blowing - Electrical - DIY Chatroom Home Improvement Forum
Old 01-12-2007, 07:28 AM   #1
Rewards Points: 150
Light keeps blowing
I have a lamp post by my walkway, I put a new bulb in and it blew, put another one in and that blew. Must be a short somewhere? where should I start looking? underground cable? socket?
econdave is offline   Reply With Quote
Old 01-12-2007, 07:36 AM   #2
It is extreemly unlikely that you have a short circuit.
You may have something miswired, or you may have too much voltage. What type of light is it, and what type of bulb are you trying to use?
jwhite is offline   Reply With Quote
Old 01-12-2007, 11:28 AM   #3
Turn off the power to this unit and check to see if there is moisture/water inside the socket for the bulb.
redline is offline   Reply With Quote
Old 01-15-2007, 09:42 AM   #4
Electrical contractor
RobertWilber's Avatar
Robert Wilber
Licensed Philadelphia Electrician
Philadelphia License # 3516 - 16765
Have you taken a voltage reading at the light fixture?
RobertWilber is offline   Reply With Quote
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 10:44 PM
Part of a ceiling fan light fixture needs help...please g5729 Electrical 1 06-17-2007 07:22 AM
2 switches to same light use 1 for another light gmcclel Electrical 9 05-29-2007 02:30 AM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 08:11 PM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 07:02 AM
