Light Inside Of A Cabinet - Electrical - DIY Chatroom Home Improvement Forum
Old 02-19-2009, 08:07 PM   #1
light inside of a cabinet
i would like to put a under cabinet style light in a large pantry style cabinet that we have.
I would like to have the light come on when it is opened and off when it is closed, like a refrigerator.
is there such a thing that would enable me to do this?
rustic is offline   Reply With Quote
Old 02-19-2009, 08:19 PM   #2
Door switch or micro switch.
A standard door switch is cut into the door jamb. It has a very small metal jbox.
If it's a cupboard door you are going to have to get creative. Maybe a lowvoltage micro switch and a relay to control the light.
Or....once again...a motion detector. It won't shut off right away (probably 60 seconds minimum ) but it will be easier to install.
I recently saw a surface mounted ceiling fixtire with a MD built in.
220/221 is offline   Reply With Quote
Old 02-19-2009, 09:50 PM   #3
J Calvin Construction
jcalvin's Avatar
Rewards Points: 150
we used rope lighting in a case like this. run it on the inside of the cab toward the front. we always wired a switched rec. above the cabinet and controlled it with a switch nearby. microswitch would be nice but never had anyone that wanted it over the standard switch. rope lighting worked excellent.
Cal
You hired WHO?
jcalvin is offline   Reply With Quote
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 11:40 AM
Grout question poolecw Flooring 11 10-29-2008 08:32 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 09:19 PM
Electrical for disposal - box inside of cabinet? pcampbell Electrical 1 05-07-2008 09:18 AM
