Light Help - Electrical - DIY Chatroom Home Improvement Forum
Old 09-02-2012, 07:26 PM   #1
light help
hello, I am hoping you can help out.
Issue: circuit blowing with switch in place
wiring in use is 12-2
in use
1- light (front post light) (2-25 watt bulbs)
1-photcell (for post light)
1 - 500watt halogen
1-switch (for halogen)
15 amp breaker
all components connect at one juntion box
connections
post light - hot\neutral to hot\neutral of circuit
halogen- black>switch|switch>hot(circuit)
All neutrals together
grounds together
If I run both lights directly from the circuit I have no issues at all
With the switch for the halogen light in place the circuit blows within 30 seconds
The switch for the halogen seems to be the problem area I just dont know why
I have changed the halogen switch
I have changed the photocell
I have change the wiring from the switch to the junction
thanks for any help!
duelman is offline   Reply With Quote
Old 09-02-2012, 08:46 PM   #2
Electrical Contractor
kbsparky's Avatar
Disconnect the halogen light at the fixture. Cap off the wires.
Restore power, and try the switch again. Does it trip?
If so, something is bad in your wiring.
If not, then you may have a bad fixture.
Or you could have a bad/weak breaker.
-KB
dimmer 'crossfade' when combining light circuits mitchl Electrical 8 12-11-2011 03:00 PM
Help wiring ceiling light wylde8 Electrical 1 09-24-2009 06:29 AM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 08:19 PM
