Light Fuxture - Electrical - DIY Chatroom Home Improvement Forum
Old 03-06-2011, 06:25 PM   #1
Light fuxture
I was installing a light fixture and I connected the white to the white and the black to the black, However I did not connect the new ground to the existing ground because the existing ground was attached to the existing box, so I figured I didn't need to. Is this going to be a problem in the future? I dont want my house to burn down...Thanks for all responses
Kysin is offline   Reply With Quote
Old 03-06-2011, 06:37 PM   #2
DIY staff
Rewards Points: 7,174
If the box is grounded and the fixture is screwed into the grounded box---you're fine.---Mike---
Old 03-06-2011, 06:40 PM   #3
Mike you are the best, big relief to know that....much appreciated
Old 03-06-2011, 06:44 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I don't think anything is going to burn down but depending on how the fixture is constructed, you could end up with the fixture not being grounded. That would be a safety hazard and should be fixed.
Old 03-06-2011, 07:09 PM   #5
Rewards Points: 1,418
Screw the ground wire that came with the fixture to the box. This is typically done when the box is up against a wood stud and you drill a 1/8" to 3/16" hole (unless a hole already exists) in the box only. Or clip this wire to the rim of the box using a clip (sold separately) meant for this.
Help wiring ceiling light wylde8 Electrical 1 09-24-2009 07:29 AM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 08:52 PM
Grout question poolecw Flooring 11 10-29-2008 08:32 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 09:19 PM
