Light Flickering While Using A Hair Styling Iron - Electrical - DIY Chatroom Home Improvement Forum
Old 11-19-2012, 03:24 PM   #1
Light flickering while using a hair styling iron
Hello.. I have a concern..hope someone can offer insight..this has never happened before. I bought a curling/straightening iron called "Instyler"..while in use it causes the light in the room to flicker. Is this normal? Power of the curling iron is 120 Volts, 60 Hertz and 135 Watts.
karen6101 is offline   Reply With Quote
Old 11-19-2012, 03:30 PM   #2
Rewards Points: 736
That's a pretty low wattage, it certainly shouldn't cause any problems. Try plugging it in somewhere else (different circuit) and see if the problem follows the iron, maybe it's malfunctioning?
TheBobmanNH is offline   Reply With Quote
Old 11-19-2012, 03:39 PM   #3
Thanks..i did try it out in another room and still get the flickering scary.. my building is old, prewar
Old 11-19-2012, 03:50 PM   #4
Rewards Points: 1,192
Reread the wattage again. It sounds too low.
bobelectric is offline   Reply With Quote
Old 11-19-2012, 04:07 PM   #5
ty..per the manufacturer it is 135 Watts
Old 11-19-2012, 05:27 PM   #6
Rewards Points: 1,452
A curling iron could well be in the 150 watt range. A hair dryer would be in a higher range like 1000 watts.
You have a loose connection somewhere, either in the receptacle you are using or somewhere upstream. You need to measure hot to neutral voltage in several places including at the panel to narrow it down, while someone else turns the curling iron on and off.
Old 11-19-2012, 07:25 PM   #7
Thanks for the info. The plug fits into the outlet, but I noticed it is the slightest bit loose. Maybe i can use an adapter to get a firmer hold?
Old 11-19-2012, 09:06 PM   #8
Rewards Points: 52
No is it a brand name product? Take it back get another.
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
The Following User Says Thank You to digitalplumber For This Useful Post:
karen6101 (11-20-2012)
Old 11-19-2012, 11:12 PM   #9
JuzRick's Avatar
Karen: it sounds as if your experiencing a overload to that particular circuit. I've troubleshooted issues as that before. Replacing that one loss receptacle will definitely help one that one note being the prongs in that receptacle is worn out. Ohming the panel to the receptacle point seeing what ur reading is will help..let you where your problem begins; then consulting with an electrician to fix the problem. Another thing would be to checking weather the line to the breaker in your panel is properly tighten.
JuzRick is offline   Reply With Quote
The Following User Says Thank You to JuzRick For This Useful Post:
Old 11-19-2012, 11:14 PM   #10
JuzRick's Avatar
It could very well be the breaker itself is defected.
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 05:28 PM
Wiring a Shed light & internal power DJDesq Electrical 4 08-12-2012 09:12 PM
flickering light bulb when switched off debiasio Electrical 9 06-19-2012 06:12 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 08:52 PM
