Light Fixtures In A T-Bar Ceiling - Electrical - DIY Chatroom Home Improvement Forum
Old 06-13-2009, 05:08 PM   #1
Light Fixtures in a T-Bar Ceiling
Hi There,
We have just installed (okay....we had someone come and install) a drop ceiling in our basement but now we do not know how to go about getting the light fixtures down from the studs they are currently attached to. I want to drop them and then add the fixtures but I'm afraid it will be too heavy. Do I have to get pot lights??? Any help would be GREATLY apprectiated!!!!!
DIYMOM&DAD is offline   Reply With Quote
Old 06-13-2009, 08:56 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
I used Halo H5 cans in my dropped ceiling. The housing comes in several varieties. For your application the two main types are H5T for incandescent bulbs and H5131C for compact fluorescents. Both types have mounting arms that connect to the track. They require 7" of vertical space but they can be spaced between the joists for more clearance.
Here is the Data sheet for the H5T:
http://www.cooperlighting.com/specfi...nfopdf/H5T.pdf
Amazon.com has the H5T
http://www.amazon.com/Halo-H5T-5-Inc.../dp/B000JFJ8CW
Here is the Data sheet for the H5131C
http://www.cooperlighting.com/specfi...df/H513_IC.pdf
EDIT:
Attached pic is from Amazon.
Bulb and Trim is not included
Disclaimer
& Stay Safe
.....Bob Lavery
Old 06-13-2009, 09:49 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
what kind of fixtures do you have now. I install 2X4 lay in fixtures all the time with no problems.
additional support wires can be added to the perimeter of the light "hole" if needed and many fixture even provide facilities to install support wires directly to the fixture.
On the job I am currently working, we have some 50 or 60 lb light fixtures (quite heavy for drop ceiling fixtures). We installed a support system where the light is not supported by the grid at all but by the support system which is attached to the hard deck.
Old 06-13-2009, 11:22 PM   #4
liscenced electrician
Rewards Points: 538
If the tbar is anything like the ones I'm used to. The grid wires are so often tha can support a lot of wieght . But fixtures should also have wires to support the.
jimmy21 is offline   Reply With Quote
Old 06-16-2009, 11:06 AM   #5
Rewards Points: 204
I would use 2x4 "lay-in" florescent fixtures. They fit in just like the ceiling panels. (they take the place of one ceiling panel). You can then drop a length of NM or MC from the light box above to the new fixture. These type of fixtures are in many many office buildings, so look around. Make sure you put blank covers on the existing now hidden boxes. Get blank covers with a KO in them. This way you can install your cable and connector into the cover. Or, just use the KO on the box itself. Some jurisdictions require a means of support other than the ceiling grid. I am not sure if it's required by the NEC. Supporting the fixture would leave no room for error.
They also make special ceiling boxes just for drop ceilings. Do some shopping, and look at the different types available.
Ceiling Fan /w light wiring question beachbone Electrical 4 02-04-2009 10:42 PM
Recessed Light on Curved Ceiling? mfleming Electrical 2 10-31-2008 06:53 PM
ceiling light power loss pejay Electrical 4 08-22-2008 05:02 AM
Ceiling Fan Light Bulbs? kennykenny Electrical 7 07-29-2008 07:16 AM
Converting wall outlet to power ceiling light? VEIK Electrical 3 07-08-2008 08:43 AM
