Light Fixture Wiring Help - Electrical - DIY Chatroom Home Improvement Forum
Old 07-11-2010, 09:00 PM   #1
Light Fixture wiring help
Hello all, we are trying to connect a new light fixture and are not sure how they should be connected.
Here are the light fixture wires:
Here are the wires on the light fixture:
jdpitt05 is offline   Reply With Quote
Old 07-12-2010, 01:36 AM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
red from the box to the black in the fixture. White in the box to white in the fixture. Bare copper in the box to the bare and green/yellow wires of the fixture.
Old 07-12-2010, 09:56 AM   #3
joed's Avatar
Rewards Points: 11,524
Bare in box to the green/yellow. The bare wire looks like it might be a safety support not ground wire. Bare hooks over the hook on the fixture mount if that is the case.
Old 07-12-2010, 10:01 AM   #4
nap
You talking to me?
nap's Avatar
a safety support? what kind of fixtures you putting in joed? I can't think of anything I have ever put in resi that had a safety support but there is that hook on the bracket (which I didn't notice until you posted) up there so I suppose it could be.
good catch it you're right.
Old 07-12-2010, 10:40 AM   #5
Thanks for the response guys. The hook is for a part on the light fixture that hooks on. The ikea booklet shows that the 2 bare silver wires and the green/yellow should go to a dotted line wire from the ceiling (i assume it means the ground?). So 4 wires together there.
I've tried red to black, white to white, and the bare to green/yellow + 2 bare silver wires. It didn't work.
Old 07-12-2010, 11:43 AM   #6
Confirm that the new IKEA fixture works by checking for a few ohms resistance with a DVM between the white wire and the black wire with incand. bulbs installed, and for infinite resistance between either colored wire and the lamp housing.
Checking the wires in the ceiling box can get a little more involved.
Old 07-12-2010, 12:57 PM   #7
nap
You talking to me?
nap's Avatar
are there light bulbs in it? (don't laugh. it happens)
turn on the switch? circuit breaker on?
was there an existing fixture? did it work?
do you have some sort of voltage tester? Check from the ground to the hot (red) for power.
Old 07-12-2010, 02:09 PM   #8
joed's Avatar
Ceiling fans are one.
Old house, having light fixture issues atomiclilly Electrical 6 12-03-2009 09:54 AM
Light fixture: Does hot&neutral designation matter, and possible wiring anomaly. Deck Electrical 8 08-26-2009 09:08 AM
Wiring of bare copper wire in a light fixture Fleet_Foxes Electrical 5 07-16-2009 09:44 PM
I can feel buzzing or "charged" air around a light fixture? jabrockson Electrical 10 03-26-2009 09:20 PM
Changing Light Fixture - Way too many wires and light wont switch off marapapa Electrical 3 01-13-2006 02:16 PM
