Light Fixture Shorted (?) After Using Wrong Bulb - Electrical - DIY Chatroom Home Improvement Forum
Old 05-30-2013, 04:18 PM   #1
Light fixture shorted (?) after using wrong bulb
Hi there,
We had these lights Installed by an electrician a few years back. The other day, I mistakenly/without thinking put a halogen bulb in it (it had the same base, correct wattage) and now the fixture won't work with any bulbs.
Aside from replacing the fixture, is there anything I can do to try fix it?
Thanks for any help with fixing my mistake.
brokenlight is offline   Reply With Quote
Old 05-30-2013, 04:25 PM   #2
Rewards Points: 12,790
Should not have mattered, thaat gulb still should have worked.
Going to have to start by seeing if there's power to the socket, look at the tab inside the fixture to see if it just needs to be pulled out some so it can make contact with the builb.
Checking the breaker by turning it all the way off and back on again.
Checking for tripped GFI.
Checking for loose or burned wiring.
Old 05-30-2013, 04:53 PM   #3
Thanks. I looked at the fixture, and it turns out that the bottom (where the bulb connects to the main wire is burned out, physically black in colour.
Am I able to shorten to the still-ok parts and reconnect to those?
Thanks for your help
Old 05-30-2013, 05:36 PM   #4
Hi,
This actually worked thanks. I just shortened the cable from where it was burned.
Old 05-30-2013, 07:07 PM   #5
Rewards Points: 6,652
Originally Posted by brokenlight View Post
Hi there,
If it had caused a short, it would have tripped a breaker. No, most likely you have either a open in the fixture causing the problem, or a open at a junction inside the box that is above the fixture, or somewhere else.
Old 05-30-2013, 11:53 PM   #6
dmxtothemax's Avatar
Rewards Points: 5,096
Something like this should be fixable !
Replace the burnt out lamp base,
Get a good quality base, not a cheapie !
Trim back any damaged wiring,
If heat build up is a problem
then use CFL's.
However cfls, also dont like heat build up.
But it will make the new base last much longer.
EASY AS !
dmxtothemax is offline   Reply With Quote
Old 05-31-2013, 08:44 AM   #7
dmx, actually the bases heat up more than just the old incandescent bulbs. The ceramic bases are the heat sink for them, unlike the old incandescent, the metal was the heat sink. Both are about the same temp.
Tags
bulb , light fixture , light suddenly stopped
Hard Wiring vanity light fixture into outlet? qwiksilvertrav Electrical 16 02-24-2013 02:16 PM
Circuit Breaker Tripping when I turn on kitchen light fixture hiker23 Electrical 2 02-04-2012 03:30 PM
converting 12 v light fixture to 110 GKA Electrical 1 06-30-2011 07:59 PM
HELP! Wiring 2 switches with new light fixture michugana Electrical 7 04-10-2011 07:49 PM
Could a older light fixture cause premature CFL light bulb failure? imola ghost Electrical 10 01-10-2010 04:53 AM
