Light Fixture Replacement - Electrical - DIY Chatroom Home Improvement Forum
Old 05-23-2011, 10:07 AM   #1
Light fixture replacement
Hi all...new to the forums here.
Last night, my old pull cord light fixture (with 1 light bulb) above the dryer crapped out; it won't shut off when the cord is pulled, so I tried to replace it.
I bought a Hampton Bay pull cord light @ Home Depot with 2 lights, but when I took it out of the box, it had 6 wires (3 White, 3 Blk), but there are only 3 coming out of the ceiling (White, Blk, and ground).
Is this common, and is it something I can put in, or do I have to stick with the one light type pullcord light?
I appreciate greatly any adice you all may have; thanks in advance.
RuffBunch is offline   Reply With Quote
Old 05-23-2011, 10:32 AM   #2
Rewards Points: 6,652
Common yes. Something you can do yes, as long as you shut off the breaker that powers the junction box. Hopefully you did not unhook anything, and leave the six wires hanging loose.
Old 05-23-2011, 10:52 AM   #3
Yes, I followed the basic stuff, but didn't want to screw anything up, so I put the old porcelain fixture back on, since the two wires hanging screwed right into the terminal screws on the fixture itself. We have to unscrew the lightbulb currently to turn it off...
I was concerned as to whether I should wire all three whites to the white from the ceiling as well as the same for the three blk wires from the new fixture to the one blk wire coming from the box as well, or if any of the 6 wires on the fixture were a ground even though they're all either white or black.
Old 05-23-2011, 11:15 AM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 254
Did you buy a fan light kit to hang from the ceiling?
If you did, I don't thnik they are listed to be used that way.
Old 05-23-2011, 11:28 AM   #5
Nope; it's a 'stand alone' light...this is it here:
http://www.homedepot.com/Lighting-Fa...atalogId=10053
Old 05-23-2011, 11:31 AM   #6
jbfan's Avatar
Rewards Points: 254
Connect all the black wires to the black wire, and all the white wires to the white wire.
There should be a bare copper wire that is the ground also.
Old 05-23-2011, 11:37 AM   #7
Just unhook the black & white from the fixture, and reverse the process. No need to undo all the wire nuts. Pretty straight forward, two wires from two screws. Black to Brass, white to silver. As for the wires on the fixture, one will be black, the other will be white.
Old 05-23-2011, 12:00 PM   #8
Thanks Gents...for 'shedding a little light on the subject', so to speak.
New Light Fixture won't turn off Aubullion Electrical 4 02-22-2011 01:23 AM
Bathroom Light Fixture with no junction box? shadowman Electrical 2 07-13-2010 07:54 AM
outdoor light fixture kills everything on circuit kramwens Electrical 10 10-10-2009 04:50 PM
Help with wiring a new light fixture tinkin3 Electrical 10 09-09-2009 10:26 PM
light fixture wiring jasjks Electrical 4 11-29-2006 03:51 PM
