Light Fixture Needs A Ground Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 05-23-2010, 10:18 PM   #1
Light fixture needs a ground wire
I recently received a hanging light fixture from a friend who purchased it at a garage sale. The light fixture has no ground wire. How would I go about installing one, or grounding this fixture without one?
Thanks in advance.
PRedLSU is offline   Reply With Quote
Old 05-23-2010, 10:20 PM   #2
Do you have a pic of the fixture ?
Usually just attach a ground wire somewhere if its metal
Old 05-23-2010, 10:22 PM   #3
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 72
Is it mostly metal, and does any metal part become in solid contact with the junction box? It probably gets it's ground that way. If it's a chained fixture, then that would not work well as the bond between each link would not be sufficient, so maybe the ground is actually missing.
Old 05-23-2010, 10:29 PM   #4
It essentially looks like the above. It hangs by a foot or so long chain and enters the ceiling through a little plate that covers up the outlet box. I suppose if I just connect a wire to the top of the lamp, run it up through the chain and around the outlet box, that would do?
Old 05-23-2010, 10:35 PM   #5
Tom Struble's Avatar
Rewards Points: 2,002
that how i usually see them done,maybe attach the wire first to a ring terminal big enough to go around the nipple and clamp it between the fixture and the finial
Tom Struble is offline   Reply With Quote
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 01:29 PM
Replaced Light Fixture, additional wire? froddan Electrical 11 11-17-2009 11:55 AM
Installing One Light Fixture Causes Another Not To Work pythagras Electrical 2 07-02-2009 09:15 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
