-   -   Light fixture needs a ground wire (http://www.diychatroom.com/f18/light-fixture-needs-ground-wire-71931/)
PRedLSU 05-23-2010 09:18 PM
I recently received a hanging light fixture from a friend who purchased it at a garage sale. The light fixture has no ground wire. How would I go about installing one, or grounding this fixture without one?
Thanks in advance.
Scuba_Dave 05-23-2010 09:20 PM
Do you have a pic of the fixture ?
Usually just attach a ground wire somewhere if its metal
Red Squirrel 05-23-2010 09:22 PM
Is it mostly metal, and does any metal part become in solid contact with the junction box? It probably gets it's ground that way. If it's a chained fixture, then that would not work well as the bond between each link would not be sufficient, so maybe the ground is actually missing.
PRedLSU 05-23-2010 09:29 PM
http://images.lowes.com/product/conv...96000467lg.jpg
It essentially looks like the above. It hangs by a foot or so long chain and enters the ceiling through a little plate that covers up the outlet box. I suppose if I just connect a wire to the top of the lamp, run it up through the chain and around the outlet box, that would do?
Tom Struble 05-23-2010 09:35 PM
that how i usually see them done,maybe attach the wire first to a ring terminal big enough to go around the nipple and clamp it between the fixture and the finial
