Light Fixture Install - Electrical - DIY Chatroom Home Improvement Forum
Old 01-26-2012, 03:35 AM   #1
Post
Can someone help me figure out how to install a lamp on my ceiling junction box? The house is brand new, so I assume the wiring adheres to the latest construction standard.
The fixture has 4 wires: one black, one white, one red, and one that is bare copper.
The lamp came with 3 wires that are not color coded. Two of the wires come in a pair similar to an extension cord (wrapped/ shielded in plastic), the other wire is exposed.
The instructions seem to indicate that the exposed wire is the neutral. So I was thinking about connecting it to the white wire. What should I do with the other wires?
NuHomeNoob is offline   Reply With Quote
Old 01-26-2012, 04:52 AM   #2
Julius793's Avatar
NO bare wire should be the ground so connect it to the bare in the box.
The black and the red are probably powered by 2 different switches so figure out which switch you want to use for the black of the lamp.
And then white (neutral) of the lamp to white (neutral) of lamp. The way to tell which is the neutral of the extension cord looking wires is, it will usually have little ridges.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-26-2012, 05:03 AM   #3
Licensed electrician
Rewards Points: 996
The ribbed side of the cord goes to the white. Bare to bare or green and any metal box or bracket. Unribbed may go to black or red, depends on the switching arrangements.
Old 01-26-2012, 01:50 PM   #4
Thanks!
Julius and Jim,
Thanks! I connected them as you said and it worked. I tried both the red and black for the hot wire - just to see what the difference was. It worked exactly the same way .
Thanks again,
NuHomeNoob
Old 01-26-2012, 02:11 PM   #5
Julius and Jim,
Thanks again,
NuHomeNoob
Hey I have a question and don't know who to ask , can I splice the underground wire that comes from the meter to extended it so it will reach my panel box
Handymanny09 is offline   Reply With Quote
Old 01-26-2012, 02:12 PM   #6
Hey can I extend my wires comming from my meter box so it will reach my panel box
Old 01-26-2012, 02:14 PM   #7
Rewards Points: 119
You might want to start a new thread.
KStatefan is offline   Reply With Quote
Old 01-26-2012, 03:51 PM   #8
I'm not sure how too lolimkinda new to this , sorry . But thanks anyway
Old 01-26-2012, 03:59 PM   #9
Rewards Points: 119
http://www.diychatroom.com/newthread...newthread&f=18
Old 01-26-2012, 04:06 PM   #10
Julius793's Avatar
And when you start a thread give us all the info you can not half.
Tags
light fixture , light installation , light wiring
Help! I need to install a new light fixture! dispietate Electrical 6 10-17-2011 05:18 AM
How many wires can be tapped into a light fixture? JayBird Electrical 6 07-11-2011 03:44 PM
Removing old light fixture & install ceiling fan sjk Electrical 3 04-17-2011 09:32 AM
Three light fixture only one light works jenwoode Electrical 1 09-21-2010 01:08 PM
New Member, New House Owner, New Light fixture kingston73 Electrical 3 09-19-2010 07:13 PM
