Light Fixture, Four Ceiling Wires? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-20-2012, 05:22 PM   #1
Question
Installing a new light fixture in the soon-to-be nursery. Under the ceiling plate was one green white. After removing some of the jacketing, there are four smaller wires: red, yellow, green, black. Pic below:
http://www.flickr.com/photos/1597122...in/photostream
Light fixture is the normal two black, two white, one copper ground.
I'm obviously a complete newbie when it comes to electrical systems but I certainly want to make sure I install this light correctly.
Any help would be greatly appreciated.
FireEMT is offline   Reply With Quote
Old 12-20-2012, 05:27 PM   #2
That's some type of low voltage wire (phone, doorbell, thermostat, alarm, ?).
Not for a typical light fixture.
I'm not familiar with low voltage lighting wiring, so I guess it could be some of that if you have low voltage lighting in your house.
wrongdave is offline   Reply With Quote
Old 12-20-2012, 05:37 PM   #3
Licensed electrician
Rewards Points: 1,506
Those are too small to be used for electrical wiring for a fixture.
Based on the colors it looks like old 2 pair phone cable.
How old is the house? Was there a fixture previously?
Old 12-20-2012, 05:38 PM   #4
The home was built in 2005. It's a "Ryan Homes" house. There was no light fixture there before but several have been added to home since it was built...
Old 12-20-2012, 05:40 PM   #5
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Are your smoke alarms hard wired?
sublime2 is offline   Reply With Quote
Old 12-20-2012, 05:41 PM   #6
Yes they are. There's already one in the same room. This plate is right in the center of the room so I would think it's obviously for a light or ceiling fan.
Old 12-20-2012, 05:44 PM   #7
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
You would think. You may be able to use the box for what you want but you will need cable to the box and the switch to achieve what you want.
Not that wire!
Old 12-20-2012, 05:46 PM   #8
Rewards Points: 150
Not with that size wire, at least for 120V lighting. That's definitely in-wall telephone wiring, 2 pair (green-yellow and red-black).
Dave632 is offline   Reply With Quote
Old 12-20-2012, 05:59 PM   #9
Well thanks for the advice guys. I'm going to try contacting the builder tomorrow for some more info. Guess I will have to get an electrician in here.
Thanks again.
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Problems with installing new ceiling light. jcpiebald Electrical 3 12-29-2011 12:14 PM
Replacing a Light Fixture with many wires flan3084 Electrical 7 12-31-2010 11:37 AM
Light fixture in ceiling fan won't work. Tested DIYself Electrical 7 11-28-2010 11:52 AM
Old house, having light fixture issues atomiclilly Electrical 6 12-03-2009 08:54 AM
