Light Fixture Doesn't Work - Electrical - DIY Chatroom Home Improvement Forum
Old 12-13-2009, 06:21 PM   #1
Monika2024's Avatar
Light fixture doesn't work
OK. Here's the deal, I decided to spray paint my half bath wall fixture. The wiring in the wall was: 2 white wires, 2 black wires, a ground wire and a green ground screw. I painted the fixture and now I re-attached everything, white to white, black to black and ground to ground and nothing. what am I doing wrong? Is the fixture ground supposed to be attached to the green screw only and the wall ground loose? That's how it looked before I took it off, but then again maybe I was seeing things. I'm scared to try anything else until I get some input. Thanks in advance.
Monika2024 is offline   Reply With Quote
Old 12-13-2009, 06:25 PM   #2
Licensed electrician
Rewards Points: 1,754
All the grounds should be connected together and to the mounting plate.
Check you connections. Vibration may have broken the bulb filament.
Old 12-13-2009, 06:27 PM   #3
Monika2024's Avatar
I tried different bulbs, and nothing. Hmmm..
Old 12-13-2009, 06:29 PM   #4
Monika2024's Avatar
OK so the two ground wires should be twisted together and attached to the green screw? Do I need one of those cap thingies on the end cause it doesn't have it like the other wires. Also, why are there two sets of wires in the wall (2black, 2 white)?
Old 12-13-2009, 06:29 PM   #5
300zx's Avatar
Post
Yes,Turn off switch or breaker and check your connections or bulbs
300zx is offline   Reply With Quote
Old 12-13-2009, 06:30 PM   #6
Monika2024's Avatar
Alright will try one more time, after that I'm giving up. Thanks.
Old 12-13-2009, 06:31 PM   #7
300zx's Avatar
Is there another light or something that turns on with the light?
Old 12-13-2009, 06:42 PM   #8
Monika2024's Avatar
Let there be light!!! I think what my problem was ...was that I didn't screw the grounds tight enough against the metal plate...if that has anything to do with it....Thanks all.
Old 12-13-2009, 06:47 PM   #9
300zx's Avatar
Post
Did you check the other connections because the ground should not be the problem in your case,
does The light have a black and white wires
Old 12-14-2009, 09:32 PM   #10
Rewards Points: 518
Originally Posted by 300zx View Post
Did you check the other connections because the ground should not be the problem in you case,
Yes, please double check your white and black connections carefully. The fixture should still work even if the grounds are not connected to anything.
n0c7 is offline   Reply With Quote
Old 12-14-2009, 09:47 PM   #11
300zx's Avatar
Post
We prob won't hear back from him until his light stops working again then he will wondering why!!
Old 12-14-2009, 09:49 PM   #12
Thumbs up
Thankfully the light works, now...! (Ignorance. (I don't mean it in a pejorative way) is Bliss, as the saying goes.) We didn't know why the light stopped working and we don't know why it's working again. Like 300ZX suggested. It wasn't because of the Ground. So It's good to keep in mind that Paint is an Electrical Insulator. Since you mentioned that you painted the fixture. It's possible that a drop of paint got on one of the terminals. (Hot or Neutral) That blocked the electricity from flowing.
Last edited by spark plug; 12-14-2009 at 09:52 PM. Reason: Incorrect spelling of a Posting Name
spark plug is offline   Reply With Quote
Old 12-16-2009, 09:23 AM   #13
Monika2024's Avatar
HI all. Actually I'm a female. And i think that when I was tightening those little cap thingies the fixture's wire kept on slipping, thus not fully being connected to the wall's wires. All fixed and the light has been working ever since. Thanks for the help.
Old 12-16-2009, 09:50 AM   #14
300zx's Avatar
Post
Sorry didn't know you were female.Glad you fixed the peoblem
Old 12-16-2009, 09:51 AM   #15
Monika2024's Avatar
No problem. Just don't do it again!
Remove old light fixture (hanging) dj928 Electrical 9 12-02-2009 11:42 AM
outdoor light fixture kills everything on circuit kramwens Electrical 10 10-10-2009 03:50 PM
Dimmer didn't work, now old light switches don't work properly townpump Electrical 9 03-16-2008 07:28 PM
Hall light worked before installing a new light fixture in bathroom jcfan7 Electrical 40 02-23-2008 09:46 AM
find switch to control outdoor light fixture CaymanAg Electrical 1 07-10-2005 08:43 PM
