Light Fixture and Ceiling Fan
hi,
i had the lights stop working on a ceiling fan that was only a year old. after some testing, found out it was the pull switch for the lights. the switches are made kind of cheap, at least mine was. if it is the switch, make sure u get a new switch with the same voltage and amp rating, as the old switch. this is VERY important, cause if the new switches amp rating is too low, it could burt out the switch. the rating of the switch should be printed on the switch somewhere....bob
