Light Fixture - Electrical - DIY Chatroom Home Improvement Forum
Old 01-17-2009, 07:52 PM   #1
Question Asker
Send a message via AIM to xamplesample
Light Fixture
if i turn the light switch off in my room, is it safe to install a new light fixture in that room , i mean, do i really have to cut the power to the whole house when i can just flip the switch to "off" and change the ceiling fixture?
xamplesample is offline   Reply With Quote
Old 01-17-2009, 08:03 PM   #2
Electrician
ctsmiths's Avatar
Rewards Points: 150
You need to kill the power to the circut you are working on because anything else on the circut is dumping current on the neutral, and thats how people die. You dont need to kill the whole house just the breaker that supplies the light.
ctsmiths is offline   Reply With Quote
Old 01-17-2009, 08:07 PM   #3
Question Asker
so...
so just flipping off the light switch isn't enough. i have to kill the power to the whole room?
Old 01-17-2009, 09:23 PM   #4
Electrician
ctsmiths's Avatar
Rewards Points: 150
Whatever is on the circut that feeds that lights or you could get yourself some line gloves and work with those, but its easier to kill the power.
Old 01-17-2009, 09:32 PM   #5
Rewards Points: 820
The problem is two fold:
First, you don't know that the person who wired the light put the switch on the hot leg.
Second, many times the outlet box for the light is a junction to other parts of the circuit, and as ctsmiths said, you can have current flowing through the neutral, and when you break that connection, you could put yourself right in the path of current and be electrocuted. You don't need a "hot" wire to get shocked. A broken neutral becomes a hot when you put yourself in the circuit.
When I work on a fixture and have to cut power to the room, I bring in a work light plugged into another circuit. I also use a (battery powered) head lamp to provide spot light.
Ultrarunner2017 is offline   Reply With Quote
Replacement Light Fixture - Speed Wire Clip? nick4597 Electrical 4 01-03-2009 01:49 PM
Hall light worked before installing a new light fixture in bathroom jcfan7 Electrical 40 02-23-2008 10:46 AM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 10:44 PM
Part of a ceiling fan light fixture needs help...please g5729 Electrical 1 06-17-2007 07:22 AM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
