Light Fixture - Electrical - DIY Chatroom Home Improvement Forum
Old 09-26-2011, 11:54 AM   #1
light fixture
The old light fixture that I am replacing has two wires joined together (green and yellow). The green splits off and connects to a pink wire coming from the ceiling and the yellow wire splits off and connects to white wire from the ceiling. This is an old condo 30+ years. Any sugesstions ? Thanks.
cmccabe is offline   Reply With Quote
Old 09-26-2011, 11:56 AM   #2
Rewards Points: 6,652
So, what is your problem with the light?
Old 09-26-2011, 07:31 PM   #3
So yellow from light to white from ceiling and green from light to pink from ceiling. Not quite sure about this old wiring, wanted to be sure. Thanks.
Old 09-26-2011, 07:40 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 152
I've never seen a light fixture with green or yellow wiring.
Old 09-26-2011, 07:49 PM   #5
Rewards Points: 150
When a electrician is low on materials, he will use any color wire to get the job done. May sound crazy, but I have seen it done with my own two eyes. They are suppose to re identify the wires with tape or paint but I guess in this case, the electrician didn't care or take pride in his work
Sunny B. is offline   Reply With Quote
Old 09-26-2011, 07:54 PM   #6
dmxtothemax's Avatar
Rewards Points: 5,098
pink and white wires coming from the ceiling !
unusual !
White is usually neutral, when used with black.
But pink !
Could be a faded red wire.
These wires must be hot and neutral.
wrong color code means could be outside code !
Green and yellow?
These colors are normally used for earth wires.
But in your case might not be !
Again wrong color code means could be outside code.
You will have to conduct some tests to confirm.
I would think about replacing the wires with correct colors.
Or maybe easier to put some colored sleeving on them.
dmxtothemax is offline   Reply With Quote
using light fixture to power 40" lcd tv? hoszor Electrical 3 07-21-2011 11:20 AM
New Light Fixture won't turn off Aubullion Electrical 4 02-22-2011 01:23 AM
Bathroom Light Fixture with no junction box? shadowman Electrical 2 07-13-2010 07:54 AM
Help with wiring a new light fixture tinkin3 Electrical 10 09-09-2009 10:26 PM
Replacement Light Fixture - Speed Wire Clip? nick4597 Electrical 4 01-03-2009 01:49 PM
