Light Fitting - Electrical - DIY Chatroom Home Improvement Forum
Old 01-05-2013, 03:01 PM   #1
light fitting
hi im trying to find out how to fit a chandelier in a middle floor flat when i cant find the joist and the ceiling is plasterboard
Jacqueline1972 is offline   Reply With Quote
Old 01-05-2013, 03:21 PM   #2
Rewards Points: 516
Explain:
1) if you know where joists are but you don't want to use them (because not centered)
2) weight of lighting fixture
3) how wiring for power and a switch will be installed
diyorpay is offline   Reply With Quote
Old 01-05-2013, 03:23 PM   #3
Rewards Points: 320
Not exactly sure of your question but it sounds like you are trying to mount a heavy chandelier where there is no support. You need to use a box to mount the light and you'll need to run the wires to it as well as a switch location. Determine where you want to mount it. Get a heavy fan box like this one...
http://www.legrand.us/passandseymour...x#.UOiYwHf-lug
You'll need to find a source of power. Either an existing circuit or run a new circuit from the panel.
teamo is offline   Reply With Quote
Old 01-05-2013, 03:23 PM   #4
Electrical Contractor
kbsparky's Avatar
... middle floor flat ...
I assume that your use of the term flat indicates you are in a place other than the US?
It would be advisable to include your location in your profile....
-KB
Old 01-05-2013, 03:27 PM   #5
all the light socket etc is there but i want to hang a chandelier instead of a shade and i cant find the joist to take the weight, as im middle floor flat is there joists lol havent a clue and neither did my handyman
Old 01-05-2013, 03:42 PM   #6
kbsparky's Avatar
You have no clue which country you live in??
Electrical codes and practices are different depending on where you live ....
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
Speedy Petey (01-06-2013)
Old 01-05-2013, 03:50 PM   #7
Rewards Points: 14,312
Time for a far more handyman.
Most often it's as simple as removing the old box and replace with one of these.
http://www.bing.com/images/search?q=...909903&first=1
It can be installed through the hole that's there now.
Old 01-06-2013, 12:46 AM   #8
dmxtothemax's Avatar
Rewards Points: 5,610
You can buy electronic stud finders quite cheap !
It's far cheaper then ripping out plasterboard.
Name:  stud finder.png
dmxtothemax is offline   Reply With Quote
Old 01-06-2013, 09:51 AM   #9
Rewards Points: 1,192
Flat means rental which means call rental company for approval.
bobelectric is offline   Reply With Quote
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Rerouting Bathroom Wiring roasted Electrical 36 05-13-2012 09:58 PM
new light to existing switched light sirsparksalot Electrical 4 04-22-2011 03:23 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
Ikea light fitting help - green/yellow wire duncmorley Electrical 7 03-21-2010 10:51 AM
