Old 04-18-2012, 11:56 AM   #1
light and fan downtream won't tirp
I currently have a shower light and fan wired downstream from a GFCI receptacle. I am pretty sure they are wired into the load side of the GFCI. I will make sure again after work today. My problem right now is the light and fan does not trip when the TEST button is pushed. Only the receptacle will trip.
What did I do wrong?
spaz619 is offline   Reply With Quote
Old 04-18-2012, 12:07 PM   #2
Electrical Contractor
My guess is you did not wire it correctly.
Is this a new gfci?
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 04-18-2012, 12:09 PM   #3
yes, its a new GFCI.
Old 04-18-2012, 12:17 PM   #4
DIY Enthusiast
sublime2's Avatar
Just in case,
It should look lime this.
sublime2 is offline   Reply With Quote
Old 04-18-2012, 12:17 PM   #5
Check the wiring when you get home.
Make sure of the line and load termnials.
If you have a meter, check the load side with the wires disconnected.
It is either wired incorrectly, or a defective gfci.
Old 04-18-2012, 02:09 PM   #6
joed's Avatar
They are not connected to the LOAD side or the receptacle is defective.
Do not PM with questions that can be asked in a forum. I will not respond.
