Light Doesn't Turn On Immediately On Dimmer Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 03-18-2009, 09:08 PM   #1
Light doesn't turn on immediately on dimmer switch
I was over helping a friend with some electrical work. There was one light that was on a dimmer switch. It hasn't always done this, but when you turn the dimmer all the way on it might take about 10 to 15 sec before the light comes on now.
Is this a bad or worn out dimmer switch? Thanks in advance
Michblaze02 is offline   Reply With Quote
Old 03-18-2009, 10:01 PM   #2
Is the controlled lamp an incand. lamp? If yes, I guess it's the dimmer, but that is a strange way for a dimmer to fail.
Old 03-19-2009, 12:00 AM   #3
Light does not turn immediately on with a dimmer switch
Sometimes the dimmers are bad. The rotating assembly inside does not make contact when you want to. Try a regualar switch; if it is bad, then the dimmer is O.K.: the line and the bulb are bad. Try a new dimmer, if the line and the light is O.K.
Gabriel24 is offline   Reply With Quote
Old 03-19-2009, 05:14 AM   #4
Yes it is a incond. it is actually a blade type, almost looks like a fuse you would put in a panal.
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
Installing New Light Switch (NOT REPLACING AN EXSISTING ONE) Light Out on Hillsboro Be Electrical 10 03-11-2012 08:27 PM
How to avoid audible buzz with dimmer switch wkend3 Electrical 4 08-27-2008 09:44 PM
Dimmer didn't work, now old light switches don't work properly townpump Electrical 9 03-16-2008 07:28 PM
help w/ dimmer switch Mack V Electrical 5 02-15-2008 10:30 PM
