Light Doesn't Come On, But Then Turns On When I Tap On The Bulb? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-27-2013, 06:52 PM   #1
Light doesn't come on, but then turns on when I tap on the bulb?
I have a really annoying problem with a few of my light fixtures. When I turn the switch on, there is one bulb that doesn't come on.
However, if I give the bulb a tap, then it turns on and stays on. Or, if I don't tap it, after a while it will come on.
Any idea what this could be?
thinksincode is offline   Reply With Quote
Old 02-27-2013, 07:12 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,274
I assume you are talking about florescent fixtures.
Verify the fixture is grounded.
Ballasts are going bad.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 02-27-2013, 07:33 PM   #3
Sorry, I should have been more specific. These are CFL bulbs, but they are standard household fixtures (sorry, don't know the technical term - One is the light on a ceiling fan, and the other is a light over a bathroom mirror.
Old 02-27-2013, 07:58 PM   #4
A "Handy Husband"
rjniles's Avatar
Bad CFL lamp
Poor connection in the lamp socket. Turn the power off (at the circuit breaker) and clean the center contact in the lamp socket.
The Following User Says Thank You to rjniles For This Useful Post:
thinksincode (02-27-2013)
Old 02-27-2013, 08:52 PM   #5
Rewards Points: 156
sometimes the center tab gets bent and doesn't make good contact with the bulb. Try bending it up slightly. *With the power off!* and see if it clears up the problem. If it does not, you may want to check the socket inside the light fixture and make sure the wires are tight under the screw terminals of the socket
av-geek is offline   Reply With Quote
The Following User Says Thank You to av-geek For This Useful Post:
Old 02-27-2013, 09:00 PM   #6
Thanks all! I'll check the contacts and try bending the tab.
What is a 2x40W light bulb? rolandasburbuli Electrical 6 05-01-2012 12:11 PM
Ceiling Fan turns on porch light jvincent57 Electrical 4 12-19-2011 10:12 AM
fluorscent light, two bulb 8 feet long. cavers Electrical 6 11-22-2011 08:03 AM
Could a older light fixture cause premature CFL light bulb failure? imola ghost Electrical 10 01-10-2010 03:53 AM
Question about light bulb burnout arc mothra Electrical 5 04-20-2009 01:02 PM
