Light Dimmer Switch At At The Ceiling - Electrical - DIY Chatroom Home Improvement Forum
Old 05-04-2011, 03:17 AM   #1
Light Dimmer Switch at at the ceiling
I am planing to put Infrared Dimmer ( up at the ceiling.
I am wondering if this will violate any code. The walls in this room is concrete block which make it difficult for me to do wiring inside. I don't want to surface mouth them.
Any advice is appreciated.
Thank you,
thone is offline   Reply With Quote
Old 05-04-2011, 08:00 AM   #2
SD515's Avatar
Rewards Points: 504
If you put the receiver/control switch at the ceiling, a habitable room still needs a wall switch.
2008 NEC Article
210.70 (A) (1) Habitable Rooms. At least one wall switch-controlled lighting outlet shall be installed in every habitable room and bathroom.
Exception No. 1: In other than kitchens and bathrooms, one or more receptacles controlled by a wall switch shall be permitted in lieu of lighting outlets.
Exception No. 2: Lighting outlets shall be permitted to be controlled by occupancy sensors that are (1) in addition to wall switches or (2) located at a customary wall switch location and equipped with a manual override that will allow the sensor to function as a wall switch.
replacing ceiling fan light switch bluesdawg Electrical 0 01-30-2011 01:46 PM
Proper way to switch a ceiling light. CoconutPete Electrical 6 06-11-2010 07:19 AM
Ceiling Fan + Dimmer Switch = BUSTED brianm Electrical 3 01-31-2010 09:28 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 03:52 PM
